Removing binding post lug nuts
mojo_13
Ive bought some r50's and also a csi25 center I would like to use banana plugs to run wire to the speaker and in the manual for both it says to "unscrew the binding post lug nuts completely to expose the binding post plugs." I see the plugs but when I unscrew the binding posts they stop at the top and won't continue to unscrew. I was just wondering if I need to pull them from this point or just turn them harder. I know this is a pretty meager question but thank you for the help.
Post edited by mojo_13 on
Screw the lugs all the way back in. You can then pry the little black caps out with the point of a knife. They come out very easy.
Hey thank you right before I read your post this is what I tried. It hadnt worked the first time I tried. Thank you for the help
Do those little caps on binding posts of the Polk speakers do anything? I mean, if you're going to put in bananas, do you just throw the caps away?
GregoryGregory
Power Amp: Emotiva XPA-3
Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
Surrounds: PolkAudio FXi A6
Rear: Polk Audio RTi A3
Sub: PolkAudio DSW Pro 500 -
Those fricken things are a PITA. I suppose they are dust caps though.____________________
Pool: Atrium 60's/45's -
I believe the reasoning for the caps was because electrical outlets in europe have a similar design to the dual banana plug layout. Apparently people were accidentally connecting an AC current directly to their speakers. I'm at a loss as to why anyone would do that...but I remember reading that somewhere on Polks website. I'll see if I can find it.
edit-here's the page explaining it. In Polk's FAQ section.
http://www.polkaudio.com/education/showanswer.php?question_num=81The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Talk about a powered speaker! I did a watt volt ohm conversion at 220vac 4 ohms that would be a 12,000 watts 60hz sine wave!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Damn...that's pushing some juice. We just need to hook up a CD player and preamp at the power plant and have them just send the signal through their lines...lol...Talk about some power.:pThe nirvana inducer-
My friend and I had to throw away a bunch of crap speakers at a warehouse facility. We juiced some with 120vac:DPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I don't have any trouble removing them. I just wasn't sure why they were there to begin with. Thanks for the info.Gregory
Thanks for the suggestions, I've been trying to remove that piece for 1/2 hour, denting and scratching the post a lot. The instructions in the manual is really unclear.
Using the knife tip is the easiest.
