Removing binding post lug nuts
mojo_13
mojo_13 Posts: 22
edited November 2009 in Troubleshooting
Ive bought some r50's and also a csi25 center I would like to use banana plugs to run wire to the speaker and in the manual for both it says to "unscrew the binding post lug nuts completely to expose the binding post plugs." I see the plugs but when I unscrew the binding posts they stop at the top and won't continue to unscrew. I was just wondering if I need to pull them from this point or just turn them harder. I know this is a pretty meager question but thank you for the help.
Post edited by mojo_13 on
  • WilliamM2
    WilliamM2 Posts: 4,781
    edited January 2008
    Screw the lugs all the way back in. You can then pry the little black caps out with the point of a knife. They come out very easy.
  • mojo_13
    mojo_13 Posts: 22
    edited January 2008
    Hey thank you right before I read your post this is what I tried. It hadnt worked the first time I tried. Thank you for the help
  • GregoryOrme
    GregoryOrme Posts: 25
    edited January 2009
    Do those little caps on binding posts of the Polk speakers do anything? I mean, if you're going to put in bananas, do you just throw the caps away?
    Gregory
    Gregory
    Power Amp: Emotiva XPA-3
    Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
    Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
    Surrounds: PolkAudio FXi A6
    Rear: Polk Audio RTi A3
    Sub: PolkAudio DSW Pro 500
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2009
    Those fricken things are a PITA. I suppose they are dust caps though.
    ____________________
    Pool: Atrium 60's/45's
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    I believe the reasoning for the caps was because electrical outlets in europe have a similar design to the dual banana plug layout. Apparently people were accidentally connecting an AC current directly to their speakers. I'm at a loss as to why anyone would do that...but I remember reading that somewhere on Polks website. I'll see if I can find it.
    edit-here's the page explaining it. In Polk's FAQ section.
    http://www.polkaudio.com/education/showanswer.php?question_num=81
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Talk about a powered speaker! I did a watt volt ohm conversion at 220vac 4 ohms that would be a 12,000 watts 60hz sine wave!
    Ben
  • comfortablycurt
    edited January 2009
    Damn...that's pushing some juice. We just need to hook up a CD player and preamp at the power plant and have them just send the signal through their lines...lol...Talk about some power.:p
  • ben62670
    edited January 2009
    My friend and I had to throw away a bunch of crap speakers at a warehouse facility. We juiced some with 120vac:D
    Ben
  • GregoryOrme
    edited January 2009
    I don't have any trouble removing them. I just wasn't sure why they were there to begin with. Thanks for the info.
    Gregory
  • teko
    teko Posts: 1
    Thanks for the suggestions, I've been trying to remove that piece for 1/2 hour, denting and scratching the post a lot. The instructions in the manual is really unclear.
    Using the knife tip is the easiest.
