Building your own sub box
Knucklehead
Can anybody get me pointed in the direction of building my own sub box, I have a 100 watt Sony amp to drive the speaker.
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Post edited by Knucklehead on
If I were going to attempt it, I'd read this first;)Good luck!!!
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=500-021 -
You'll also probably need/want access to a table saw and a router too.
thanks bro!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Knucklehead wrote: »Can anybody get me pointed in the direction of building my own sub box, I have a 100 watt Sony amp to drive the speaker.
Not enough power and the sony amp won't do it! Go here for some ideas: http://www.avsforum.com/avs-vb/forumdisplay.php?f=155.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
not sure what you mean when you say the sony amp wont do it...thanks for the link..Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I build my own subs 2. I open the Dynaudio Sub 500 box and look!!! I got a DIY sub. I opened it so It's mine.....
Tired carry on....Dan
The sony amp will work but not great. Its not very powerful & its probably got an eq built in like most amps that come from "pre-made" subs do meaning that when you do build it, it will not have a very flat frequency response. Building your own subs can yield awesome results that far surpass commercial subs, but if you are going to do it, do it right & you will thank yourself later.
the eayest way to make your own sub is a sono tibe. the seccond is a ib-sub and the 3rd is a box type.
what i would do is do a sono sub byt maje the otter endplates square then put the braceses on the out side at all 4 corners. then wrap the out side in fabric. -
thanks for all of the help! God Bless!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
This looks like a nice driver for not too much $$$
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390022594375&ssPageName=MERC_VI_RSCCK_Pr4_PcY_BIN_Stores_IT&refitem=390022603031&itemcount=4&refwidgetloc=active_view_item&usedrule1=StoreCatToStoreCat&usedrule2=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4 -
thanks gdb!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I've got a SVS dB12.1 driver I'll let go pretty cheap, though I imagine you'd need more than that Sony amp to push it. It was well taken care of and never bottomed (or for that matter even pushed too hard, 'cause my typical listening level is -15 from reference). I just upgraded to the 12.3 driver. PM me if you're interested.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
