Windows 7 Beta?
billbillw
Anyone else using the public beta for Windows 7?
http://www.microsoft.com/windows/windows-7/
I've skipped Vista so far due to the widespread complaints and its reputation for being a resource hog.
I read a few things about this new Windows 7 starting last week and decided to give the Beta a try (on a separate partition of course).
Gotta say, this OS rocks! Its faster than XP, XP 64bit, and both Vistas. Bootup time is less than XP. Shutdown time is less than XP. Stability seems rock solid so far. No BSODs. Only a few soft program lockups so far. Driver compatibility with Vista, so out the door, it is well supported. Thus far, I don't have any hardware that isn't supported with drivers. I'm using the 64bit version and I really like it so far. Networking works great. File transfers are very fast, and not nearly as many annoying pop ups as Vista.
Software compatibility seems to be much like Vista 64 and Win XP Pro 64bit. The only think I haven't been able to use so far is CoreTemp and Itunes is acting funny. The 32 bit version probably works better in that dept.
This Beta is free until August '09. There will likely be more releases before the OS goes for sale (newer Beta's or Release Candidates). So far, I'm thinking this may actually be an OS that I'm willing to pay Microsoft for. Vista certainly hasn't been. This is the rightful heir to Windows 2000 and XP Pro. In the long run, I think Vista will be looked at much like Windows ME, a bloated piece of $hit that was not executed very well!
Post edited by billbillw on
I'm DL'ing now, I'll give it a whack.
After an XP desktop meltdown at home, I've gone to Ubuntu on one of the home 'puters. I don't think I'll ever go back...
www.ubuntu.com -
I am DL it right now. Damn, takes a long time and still going after an hour (48%) on my verizonDSL....I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I have no real complaints about XP. Vista= pretty/bloated/buggy/incompatible.
I hope 7 is a winner, and is compatable with my dual boot sata setup. What MB/sata chipset do you have? Raided?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Anyone know if Firefox runs on this beta?
Is it fairly easy to dual boot with Vista? -
I'm dl'ing but will wait to hear some reports from you guys and gals about performance before installing. I sure hope this is better than Vista. I tried it and got rid of it after less than a week and went back to XP.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I have both 32 and 64 bit versions downloaded, I may give it a try next weekend."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I much prefer W2K to Win XP. XP just seems to get slower and slower on startup and shutdown. I wonder if this Beta 7 will be the same: very fast initially, then slower and slower until it's almost painful.
I would really like to have another go at Linux, and I'm sure I will sometime this year on at least one of my machines, but unfortunately, my fingerprint scanner does not yet have a Linux based driver AFIK, so I can't forget Micro$haft completely. If Linux doesn't work, unless Beta 7 is really faster over time, without hogging resources, I am going to see if I can downgrade my XP laptop with the fingerprint reader to W2K. I'm starting to have a healthy dislike for the newer Windows releases.
The 'pute I am on right now (my daughter's former laptop, now handed down to me) is running Windows 2000. I agree, it's pretty good. Still bigger and slower than need be. I might Ubuntu this one too, soon :-) -
windows 7 delayed... Microsoft is teasing the market
downloaded last night and installed on a spare drive. so far seems ok,downloading a free av for it now:)
it can still be found all over the web through torrents.
Yes firefox works on 7. Anything that works on vista works on 7 also. -
Firefox works perfect with this. Just about any MB/drive combo will work. The hardware specs are actually less than Vista.
Ben, You shouldn't have any trouble. Are your drives set up as SATA in your MB bios or IDE emulated? If they are true SATA, you should probably get the Vista drivers for the SATA/RAID controller beforehand. Good think about Windows 7, you can load drivers with a Flash drive (Vista could actually do this too) instead of dealing with an archaic floppy.
Also dual boot is no problem. I loaded it alongside of my XP install with no hassle. Just need a clean partition. -
Hey ahhh Good luck with that. While you guys are failing with 7 I mean testing out 7, I'll be down the road still using my OSX.
DanDan
Can't be installed on ntfs?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've installed it on a NTFS partition on my laptop to play with. The OS seems ok, but IE8 is really getting under my skin. Every time I change pages on the Polk site it crashes. I'm going to try FF to see if it's any better. -
FF3 seems to have corrected the browsing issues. Hopefully no other nasty surprises will pop up.:rolleyes:
I'll let you guys play first. Plus I need my wireless to work;) Worst thing is not having the right network driver:(Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
anyone know how I would go about setting up a dual boot setup with my intel mac?
and while you're staring at your pretty mac I'll be playing Fallout 3, good luck with that or almost any of the other 40 programs I have installed running on a mac....really, do we have to do this again.Hey ahhh Good luck with that. While you guys are failing with 7 I mean testing out 7, I'll be down the road still using my OSX.
Dan
Why is it every time someone starts a thread about Windows the mac fanboys start in??? -
Not a fanboy. I wanna dual boot so I can play games too and why not? I just don't have $200 to spend on an OS, so if this is a free one...
Airplay355 wrote: »Not a fanboy. I wanna dual boot so I can play games too and why not? I just don't have $200 to spend on an OS, so if this is a free one...
Only free during the Beta period. It WILL expire after approx 7 months. If that's your idea, find an old copy of XP somewhere if ya know what I mean.Ben wrote:Can't be installed on ntfs?
Ben, AFIK, it runs on NTFS, just like XP, Vista, etc. As far as drivers, if your network car/wireless has a vista driver, then you are all set.
Like I said, I just installed mine on a clean partition that I had (made with XP Pro). Most of my system is about 1-2 years old and just about every piece of hardware was working after the install. I think the only things that weren't working were my webcam, my soundcard, and my scanner. A few other things were updated just to be current (video card, etc.)
All in all, it was the easiest install that I've ever done. -
I just finished upgrading the machine from Vista; nice interface. One major issue (that I attributed to my carelessness for not doing my research), is Workgroup file-sharing stop working. My Mac can't find this PC anymore. Windows 7 replaces Workgroup with Homegroup, that requires ALL other PCs in the network to have Windows 7. Well, I have 2 Vista (one after this upgrade), 2 XPs, and 1 Mac OS X. I guess I can go back to SnickerNet to transfer files between Mac and Windows 7 (which unfortunately is the main hub for all of my files). Oh, Well.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I'm considering installing it. But, then again, not sure I want to reinstall everything on my computer (take the time that is) when Vista works just fine for me.
moving data into a folder now...Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ha! You just could not resist the temptation! I knew it!
I am reporting to you from W7 beta. No I can't resist. IE sucks real bad. I had to go chrome for now. I did the performance tweaking to get rid of animated fluff... runs real nice for now. Drivers were a breeze. All I did is point to the system folder in Vista, and I was done in minutes. I started the install at 1:15 It would have gone real fast if I installed to one of the striped raids, but I had data there I did not want to sort through. Again the driver thing was a breeze. We shall see what happens:eek:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben, I told you it was easy! I like the IE8, what don't you like? I also tried the windows live essentials. The new Live Mail is pretty sweet.
FYI: On my system, that stupid ClearType stuff made everything look fuzzy. If you have that problem, I recommend disabling it for the clearest display.
Slight problem with my setup, all my fault though. I ignored a virus warning on something I thought would be safe. Doh! I immediately ran a full scan, but it didn't find anything. Two days later, it reared its ugly head (trojan horse).
Easy fix though. Boot to safe mode w/networking. Run online Ewido scan, cleaned and back to business. -
Guys, any suggestion for (a) course of action in opening up Homegroup file sharing with any other OS/platforms or if you could point me to any resources?
TIAI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
TIA
I'm no expert, but maybe try using Apple's Bonjour program. You might have to get out of the Homegroup to get it to work though. I haven't really done much with the networking aspect of Win 7 yet because my wife has had her laptop at work for the last few weeks. -
Thanks, Bill. I'll give it a try with Bonjour and see where it takes me.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
UPDATE: No dice on Bonjour.
However, I am convinced 150% now that Homegroup is the culprit. I can Ping my Mac from the Windows 7 machine, but not vice versa. Hence, I could copy files off my Mac from Windows 7 machine, but not the other way around. Minor inconvenience at this point, as long as I can get access files in both machine, whether it is Pull or Push.
Now that we narrow down this whack job (since if you think about it, it doesn't make sense and no group protection when there is a way to grab the files still.) I hope they don't plug this hole later on with an update, then I'll be screwed. Either that, or some Mac's jockey would find a way to hack through the smb workaround).
Any expert in opening up specific Windows 7 DNS/IP address?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
