Best New HT Speakers with old RT25i
surprise
surprise Posts: 3
edited January 2009 in Speakers
Well I have decided that it is about time to step up my HT setup and need your help deciding on the direction that I should go. My current setup is a simple Denon stereo receiver, a pair of RT25i's and a psw10. I am really happy with RT's that I have and would like to use them in the new setup.
At the moment I will purchase either an Onkyo 606 or Denon 1909 receiver, obviously to take full advantage of either receiver I will need to add a center channel and two additional speakers. My room is only large enough for a 5.1 setup. Following are the components that I am considering.
Option 1:
Front: RTi A3
Center: CSi A6 (luckily I have plenty of room)
Rear: RT25i
Option 2:
Front: RT25i
Center: CSi A6
Rear: FXi A4
Option 3:
Front: RT25i
Center: CSi A6
Rear: RTi A1
Option 4:
Suggestions?
Do you think any of these options will sound good together?
The only caveat is that I need to use bookshelf speakers for the fronts.
So what do you think? Can you help a newbie out? Which one would you choose?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    I'd go with option 1 myself. The RT25i would be a good match for any of those speakers though.
    The Onkyo 606 is a great entry level receiver. That's what I have, just know that it doesn't have any pre-amp outputs though. So if you ever intend to hook up an external amplifier with your system, you'd do better to look at the 706 or 806. That fact aside though...the 606 is a great receiver.
    By the way...welcome to Club Polk.
    Curt
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • GZ
    GZ Posts: 343
    edited January 2009
    As long as you're happy with them why not just add another pair of RT25i's for the rears. They can be found on ebay now and then.
  • surprise
    surprise Posts: 3
    edited January 2009
    GZ wrote: »
    Good idea, might have to hunt around a little. Thanks!
    Any other suggestions for a 90% HT 10% music setup?
  • curved
    curved Posts: 664
    edited January 2009
    I would have to say option 1 as well.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
