Old Polk Audio Center Speaker
Hi,
I have an old (8 years) polk audio center speaker. I was looking for the model number but I cannot find it along the outside anywhere. Is there a way I can find out the model number?
Does anyone know what was the max watts the speaker can handle (80, 100, etc)?
If I get a pair of Bose 301 speakers, will it be compatible with my center speaker or will there be sound problems?
Thanks,
Mark
Thanks,
Mark
It might help to post pics if possible. Or at least a description with dimensions.
Also, take a look here: http://www.polkaudio.com/search/older.php -
Pictures please.
Nothing goes with Bose....Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard -
You're trying to match Bose? Go find yourself an AM radio from 30 years ago and yank out the speaker.
;);) "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
