Old Polk Audio Center Speaker
mark1110
edited January 2009 in Speakers
Hi,
I have an old (8 years) polk audio center speaker. I was looking for the model number but I cannot find it along the outside anywhere. Is there a way I can find out the model number?
Does anyone know what was the max watts the speaker can handle (80, 100, etc)?
If I get a pair of Bose 301 speakers, will it be compatible with my center speaker or will there be sound problems?
Thanks,
Mark
  • cambir
    edited January 2009
    It might help to post pics if possible. Or at least a description with dimensions.
    Also, take a look here: http://www.polkaudio.com/search/older.php
  • Igo
    Igo
    edited January 2009
    Pictures please.
    Nothing goes with Bose.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
  • seeclear
    edited January 2009
    You're trying to match Bose? Go find yourself an AM radio from 30 years ago and yank out the speaker. ;););)
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
