Help please Guys - Biwire question
zebmaster
zebmaster Posts: 6
I have the RTi70 speakers, the Onkyo SR800 receiver and I just got the Monster Biwire Z2 cable with the monster lock pin endings.
The lock pin wont fit into both the RTi 70 or receivers binding post.
Am I doing something wrong, if not, is there a connector that I can buy to fit onto speaker wire ends that would fit into speaker and receivers binding post?
Television: Hitachi S500 51" Widescreen
Receiver: Onkyo, SR-800
DVD Player: Denon 2900 - M1000
Comcast HDTV Motorola 5100 - M1000
Fronts: RTi70's (Bi-wired w/ Monster M1.4's)
Center: CSi40 (Bi-wired w/ Monster M1.4's)
Subwoofer: Polk 505 - Monster MSB1000 cable
Surrounds: FXi30's
Rear Surrounds: RTi38's
Brickwall PWRM20AUD
Post edited by zebmaster on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2003
    Monster sells 'connectors' to screw onto those 'pins'.
    Choose pin, spade, or banana, I think they run around $20 for a set of 4.
    Cheers,
    Rooster
  • danger boy
    danger boy Posts: 15,722
    edited June 2003
    Russ is right again.
    yeah the moster locks are just the connector to the bi wire.. you then need to purchase whatever connector type you like. at an additional cost. like Russ said.. banana plugs, spades, or pins. I use banana. they're the fastest to disconnect when needed.
    PolkFest 2012, who's going>?
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2003
    Cheers,
    Rooster
    I think I've got a bunch of the pin style connectors from the M1.4 bi-wire set I bought from Mantis.
    Let me know how many you need (if you are interested) and we'll work a deal better than $20/4.
    Doc
    SVS
  • mantis
    mantis Posts: 17,378
    edited June 2003
    You have a bunch of Banana and spade type from me.These will work for yeah.Banana is the key.Most av receivers don't like anything else....the pins are for spring clips.
    Dan
  • dthomps
    dthomps Posts: 352
    edited June 2003
    Hey Doc-
    If zebmaster doesn't buy any of your monster connectors, I will be needing some pretty soon. Several runs of z2's became mine after my dad upgraded but took the connectors.
    Let me know.
    Thanks a lot.
    Mike
    Surfbum72@worldnet.att.net
  • Dr. Spec
    edited June 2003
    I have eleven (11) banana plug screw on connectors for the Monster Cable system.
    It's an odd number, but that's what I've got left.
    http://www.monstercable.com/productPage.asp?pin=603
    My M1.4 system is already connected (obviously) with spade connectors on the speaks, and banana plugs at the 3803 - so I'm all set.
    Dan was obviously very generous by including a bunch of both styles so I could hook up as needed.
    Parts Express sells for $12.50/pr + s/h. If I had twelve (12) it would be perfect since you would need two (2) per each channel at the amp. But I'm missing one. Sorry.
    For a Club Polk member, my offers stands to beat by a good margin the lowest on-line price anyone can find.
    Doc
    SVS
  • zebmaster
    zebmaster Posts: 6
    edited June 2003
    I want thank you guys for all the responses. I went to tweeter and picked up a couple boxes of the connectors. Thanks again.
    Surrounds: FXi30's
    Brickwall PWRM20AUD
  • Dr. Spec
    edited June 2003
    dthomps (Mike) - you've got email. They're yours if you want 'em.
    Doc
    SVS
