2 subs???
I have a Pioneer Elite vsx-91txh reciever...I currently have one sub connected using the sub out terminal...if i wanted to connect another sub, how might i go about doing that??
Use a Y-splitter. Male to two females, you can pick one up here:
http://www.bettercables.com/audio-y-splitter-cable.aspx -
What he said.
If you're going to connect two subs, you're better off using two of the same subs. Using different kind of subs can really degrade your bass rather than improve it. This isn't necessarily true all the time...but it is in a lot of situations. Just some advice.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
this is like $8
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
