2 subs???
tyatnu82
edited January 2009 in Speakers
I have a Pioneer Elite vsx-91txh reciever...I currently have one sub connected using the sub out terminal...if i wanted to connect another sub, how might i go about doing that??
  • MikeC78
    edited January 2009
    Use a Y-splitter. Male to two females, you can pick one up here:
    http://www.bettercables.com/audio-y-splitter-cable.aspx
  • comfortablycurt
    edited January 2009
    What he said.
    If you're going to connect two subs, you're better off using two of the same subs. Using different kind of subs can really degrade your bass rather than improve it. This isn't necessarily true all the time...but it is in a lot of situations. Just some advice.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • SlowcarIX
    edited January 2009
    this is like $8
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • Face
    edited January 2009
    SlowcarIX wrote: »
    this is like $8
    You can find them at most Radio Shacks.
