Newbie Bi-Amp Question...Sorry
infiniti16
infiniti16 Posts: 6
Hi everyone, its my first post on this forum and Im sorry if this is a question that has already been answered and I just need to search harder. I recently bought a pair of RTi10's and have them set up on my Sony STRDG720 amp. I have another receiver that I would like to use to Bi-Amp these speakers. My question is; Can I just connect one set of speaker wire from the Sony receiver to the top terminal on the RTi's and then connect another set from my Yamaha receiver front terminals to the bottom of the RTi's and have that work? I just dont want to hook it up like that without realizing its a huge issue and do some catastrophic damage or anything like that. Im also curious to know if I have to run any other connections between the two receivers and if I have to have the second receiver on a special setting or input mode to make it work. Any advice that could be given would be really appreciated. Thanks.
50" Samsung PN50A650 Plasma
PS3 - Blu Ray
Motorola HD PVR - Cable
Denon AVR- 2309CI AVR 7.1
Polk RTi10's Fronts
PSB Alpha C1 Center
Polk RTi6's Surrounds
Bose 161's Surround Backs
PSB Alpha SubZero Sub
Post edited by infiniti16 on
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2009
    What you're talking about is called bi-wiring and has very limited advantages.
    Bi-amping is a little more involved and can make for noticeable differences.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    Do you have any way to link the two receivers together? I'm not quite sure how that would work.
    I wouldn't imagine the results from that would be to good though. The two receivers are very different from one another, and probably wouldn't sound very natural together powering the same speaker.
    If you're set on bi-amping them, you probably ought to look into some external amps.
    By the way, welcome to Club Polk! :D
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Devy
    Devy Posts: 1
    edited January 2009
    hi
    this is very cool site. to get good deal same car. click here
    New cars
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    reported yo ****.
  • infiniti16
    infiniti16 Posts: 6
    edited January 2009
    Thanks for the tips guys. I ended up doing what I think is bi-wiring them. I ran wire from my front A terminals on the receiver to the bottom terminal of the speaker, and then ran some wire from my surround back terminals to the top terminal of the speaker. After a bit of auto calibration with the mic that came with the receiver and some adjusting myself, it sounds pretty good and a bit better than before. I'll leave it at that for now. Thanks again.
    PS3 - Blu Ray
    Polk RTi10's Fronts
    PSB Alpha C1 Center
