Why not MOMO?
seeclear
seeclear Posts: 1,244
edited January 2009 in DIY, Mods & Tweaks
Thinking about a sonosub build, I am thinking a 15" driver in a 24" tube, and I see lots of recommendations for drivers-soundsplinter, etc. Why couldn't (or wouldn't) you use a MOMO like this?-->
MOMO 2154
Electrical
Overall Frequency Response 18Hz-150Hz
Nominal Impedance 4 ohms
Minimum Impedance 3.5 ohms
Power Handling (continuous) 400 w
Power Handling (peak) 800 w
Efficiency 90 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 63.40 oz.
Driver Mounting Depth
Top Mount 7-3/8" (18.73cm)
Bottom Mount 7-15/16" (20.16cm)
Cut-out
Driver Cut-out Diameter 13-7/8" (35.24cm)
Thiele/Small Parameters
Recommended Enclosure Sealed / Ported / Bandpass
Resonant Frequency 24 Hz
Qms 10.21
Qes .49
Qts .47
Vas 6.595 cu.ft/186.75 L
Bl 15.8 Tesla Meters
Sd 126.22 sq.in. / 814.3 sq.cm.
Xmax (linear) .37 in. / 9.5 mm
Xmax (mechanical) .79 in. / 20 mm
Le 3.01 mH
Other
Product Weight 22.50 lbs.
Not enough xmax? Resonant frequency too high? What other parameters are most important in looking for a driver for a ported sonosub design? For $90, the MOMO looks like a bargain, but I don't want to be penny wise and pound foolish. Thanks in advance for your input.
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Post edited by seeclear on
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2009
    I'd use it.
    Usually a car sub has a higher resonance since the car boosts the low end a lot. This sub is excellent at 24 Hz.
    Sometimes the VAS(stiffness compared to surface area) is very low meaning the box will be tiny and raise the resonance more than what is acceptable, but yours is an exception. A combination of Vas and Qts will hint to the box size and cutoff frequency.
    The last thing is that few people go for accurate reproduction in a car, so the design of the sub is often compromised to match the buyer's goals(thump, thump, thump).
  • Conradicles
    Conradicles Posts: 6,419
    edited January 2009
    Interesting!
    Thinking about using a 15" MOMO in a small sealed enclosure for my H/T.
    Dayton has a sweet amp that would provide the power.
    Crutchfield has "Buy 1 Get 1 Free" now...
    I could give the free sub to a polkie for dirt cheap.
    Build my own box to fit behind my couch (I have a small living room).
    What do you guys think? I love the idea of not having an amp in my sub box. That way if the amp is in my audio rack, you can always be flexible and change subs later.;)
  • nfa_Kbc
    nfa_Kbc Posts: 10
    edited January 2009
    I'm running 3 10" Alpine type 4 10's in a 24" sonotube tuned at 25Hz, all I can say is it sounds absolutely amazing!!
  • bikerboy
    bikerboy Posts: 1,239
    edited January 2009
    It would be a lot better in the car audio forum.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
