Replacement driver/woofers for Bose 601 II
LCruiser122
LCruiser122 Posts: 23
edited January 2009 in Vintage Speakers
First, my 10As are more important to me but....
I was given a pair of Bose 601 series II. They are missing the driver / woofer. (2 each) The guy's kid took them out for his car stereo years ago. The kid was nice enough (i guess) to put 1 radioshack driver in each speaker tho...lol.
Anyway, I love the tweeter array and want to try to pair them as surround speakers. I need to replace the drivers but Bose no longer offers them.
Anyone know of a good replacement or where I might fond something. Bose or aftermarket? I was hoping someone else had this issue. I know this isn't Polk related and hope I'm not doing anything wrong.(I'm new here)
Post edited by LCruiser122 on
  • DollarDave
    DollarDave Posts: 2,575
    edited December 2008
    Call Partsexpress and they should be able to recommend a comparable driver. Given the quality of the originals, it won't cost you much.
  • LCruiser122
    DaveMuell wrote: »
    lol,
    I did call them. 7-1/4" inside dia. limits choices somewhat.
    They recommended a pioneer. $43
    Bose used to have a replacement for $46. can't get them direct anymore.
  • DollarDave
    lol,
    Well, either spend $86 on speakers worth $23, or, get out a router and make the holes bigger to open up your options, or, chunk them and get some speakers that will make you smile.
    Pick up a pair of M3's or M5's for less than $75 and be a happy camper when they mate real well with those monitor 10s.
  • LCruiser122
    I have to say that ALL my other speakers are POLK, but these 601s are CERTAINLY worth putting $100 to $150 into. They are in mint condition otherwise. The tweeter array sounds great in the upstairs bedrooms.
    I have a Cape cod, room has slope and is about 25' x 30' and those tweeters make the sound fill ALL the room. Great speaker for my bedroom, sounds like surround w/ only 2 speakers.
    I may use a router , I was hoping for advise of BRAND of driver or particular model if anyone has done this before.
    BTW, I currently use a pair of Polk S4 for side surround, I just have a feeling about that tweeter array.
  • DollarDave
    I actually like the 601's - anyone local with them contact me and I will take 'em off your hands for a while. The 601's and some series of the 901's are arguably pretty good speakers.
    I think the 7 1/4" drivers are actually 8" and you can catch them on e-bay fairly often. Measure the backet and see what you really have..
  • LCruiser122
    Correct, they are 8".
    Any idea where I can get opinions or reviews on 8" drivers?
    I'd like to know what Brand people around here consider quality drivers (8").
  • comfortablycurt
    comfortablycurt Posts: 6,745
    This place has some 8" woofers for a Bose 601 Series 3. I'm not sure if that would fit or not. It says it requires a 7" cutout diameter. They're used I guess, but it says they've been re-foamed and they have good voice coils.
    Scroll down a bit and you'll see them, they're about halfway down the page.
    http://www.oaktreeent.com/Bose_Speaker_Parts.htm
    You're sure you don't wanna keep those nice Radio Shack drivers in there? :p
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ben62670
    ben62670 Posts: 15,969
    Check ebay. I seem to remember them having replacements, and foam repair kits pretty cheap.
    Ben
    Ben
  • LCruiser122
    lol.....
    I don't know how comfortable I am with used.
    I'll probably go aftermarket.
    Just ordered tweeters for my 10As from Polk.
    I may order drivers too (4). Mine are fine but...see below.....
    Bums me out , because the last time I called Bose I could have bought the drivers/woofers for the 601s from them. Not any more tho. Now I worry same might happen with Polk.
    Anywhere else to get speaker replacement besides Parts Express? (taht anyone would recommend)
  • LCruiser122
    edited January 2009
    I can't get the 8" drivers from Bose. I am going to have to go aftermarket. I notice there is an 8" woofer in the Polk Lsi15. Think that might work?
    I have Polk 10As with smaller drivers. Are there any "older" model Polks that used 8" wooders or drivers?
  • hoosier21
    hoosier21 Posts: 4,420
    edited January 2009
    http://layneaudio.hypermart.net/
    His website is not greatest and has not been updated since I first bought from them, but the guy is great. On the "Brand List" he has the 8" Bose mid/woofer listed for 49.00.
    Damn I am getting old, I can't remember the dude's name, it is a one man show, so he might not answer on the first call.
    Russ
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 51,999
    edited January 2009
    hoosier21 wrote: »
    Now, there's an understatement. ;)
