Best LCD cleaner?
brettw22
I want to get a good LCD cleaner for my Sony LCD tv, but wanted to look at alternatives over the Monster kit that has very little solution for over $20.....
What do y'all use? Are there varying degrees of microfiber cloths (smooth, rough, etc)?
Lemme know some to check out......the last thing I'd ever be doing to this is Windex or anything of the sort (though that was fine for my 40" glass tube Mitsubishi over the years).......thanks.....
Post edited by brettw22 on
I use Monster only cause I got it free. I did notice that Phillips has the same thing just diff. bottle at Walmart for around 15$
is it a bottle of about 6 measly ounces? There's got to be something that has a good amount of the stuff for not a raping........comment comment comment comment. bitchy.
Here ya go.
http://www.target.com/Butler-Chemical-Iclean-Cleaner-Protectant/dp/B0000W2G3W/sr=1-1/qid=1230669041/ref=sr_1_1/191-1916640-2372069?ie=UTF8&index=target&rh=k%3Alcd%20cleaner&page=1
http://store.wholesaleav.com/butchemiclcd.html
http://cgi.ebay.com/New-Butler-Chemical-iClean-LCD-PDA-Plasma-DLP-Cleaner_W0QQitemZ120353392621QQcmdZViewItemQQimsxZ20081222?IMSfp=TL081222112002r17629
Bulk:
http://www.photodon.com/solutions.htm#4504 -
For quite some time I've used a 50/50 soulution of distilled water and white vinegar on a microfiber cloth. I use it for my laptop screens and LCD TVs. Works great and cheap too. This came from PC magazine or someone similar IIRC."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
ww.consumer.philips.com/consumer/en/us/consumer/cc/_productid_SVC2540_27_US_CONSUMER/Plasma-and-LCD-screen-cleaner+SVC2540-27#/consumer/en/us/consumer/cc/_productid_SVC2540_27_US_CONSUMER/Plasma-and-LCD-screen-cleaner+SVC2540-27
this is the one I saw -
Here are a couple of sites I found after a quick search that recommend this method...
http://pcsupport.about.com/od/maintenance/ht/cleanflatscreen.htm
http://cleaning.tips.net/Pages/T0169_Cleaning_an_LCD_Screen.html"Just because youre offended doesnt mean youre right." - Ricky Gervais
Klear Screen
http://www.klearscreen.com/
I use and recommend it.
Have a $4000 MacBook Pro with flawless screen along with using it on our Sony SXRD television with no issues whatsoever. -
Stay away from Phillips, I got terrible results from their Pre-packaged wipes, Dryed up smears that were a pain in the butt to come off. I know you dont get much for your money with Monster, but I'll pay for it anyday.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
premixed with no messy mixing, all for 3.99
http://www.drugstore.com/products/prod.asp?pid=12601&catid=662&trx=PLST-0-CAT&trxp1=662&trxp2=12601&trxp3=1&trxp4=0&btrx=BUY-PLST-0-CAT
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I actually like the Monstercable scren clean better then any other product I have used. Whoever makes it did it right. For 30 bucks you get the towel and it will last you years.
I think thats a fair price for how long it's going to last.
DanDan
Russ
What pads would you recommend to use with that cleaning solution?
BTW you are one sick puppy Russ...and I mean that in the nicest of ways!"Just because youre offended doesnt mean youre right." - Ricky Gervais
I never needed more than plain water on a very soft cloth. How dirty are you getting your screens?
is there something wrong with regular cleaning solution like windex (or just water like william said)? I've always used that on my laptop screen on a microfiber cloth and I've never noticed any problems- still smooth and shiny. Never tried it on my tv though- is there some reason you're not supposed to use that stuff?
I use the generic "Member's Mark" eye glass cleaner solution at Sam's club and use a microfiber towel. Works better than that overpriced Monster solution.
I would NEVER use glass cleaner on an LCD screen (unless the screen is glass)
Windex has ammonia which I don't believe is friendly to non glass screens and can cause major problems with long term use.
YMMV but that is my experience and what I have found during research.
Windex on glass, specialized TV/LCD/monitor screen cleaner on non glass screens. -
One of those green scotch-brite pads and some 409 will clean it up right :eek:
And yes I am kidding!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I use this, Brett:
http://www.amazon.com/CleanDr-60600-Plasma-Screen-Cleaner/dp/B0016A63I6/ref=pd_cp_e_2?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B0009SHDGC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0X88PPZAMQE1Q4FPJ8V8
works great for me.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Stoner's product. "Invisible Glass". 'Nuff said.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I use a Swiffer to remove dust followed by a microfiber cloth moistened with water. If there was a spot that needed more attention, I would use my home-made eyeglasses solution, which is a drop of Dawn dishwashing liquid in 8 or so oz. of water. That's how I refill my Sam's Club bottle, and it's worked great for years on a variety of A/R coated lenses. It's important to remove loose dust first. For eyeglasses, I rinse with water, then spray some solution, dry, rinse with water again, and dry with a different cloth.
I use Audioquest CleanScreen. Very simnilar looking to the Monster stuff - blue gel; comes with the cloth - but it was only about $22 local, in-store IIRC.
Here's a few online places:
http://www.onecall.com/ProductDetails.aspx?id=27560
http://www.amazon.com/Audioquest-AQTVCLEANKIT-AudioQuest-screen-cleaner/dp/B0009XVS8Q/ref=sr_1_2?ie=UTF8&s=electronics&qid=1230875549&sr=8-2
http://www.hometheaterstore.com/AudioQuest_CleanScreen_for_Glass_Plastic_p/cleanscreen.htm
