Optical V. Coax Audio Connection
TheMARPATNinja7
TheMARPATNinja7 Posts: 150
Is there any true difference between the two or are they going to do the same for me? I currently have a Optical for my XBOX and a Coax for my BD Player. Should I leave the Coax for my BD player or buy an optical cable when I get a new receiver?
Post edited by TheMARPATNinja7 on
  • danger boy
    danger boy Posts: 15,722
    edited December 2008
    as long as the audio is heard from your XBox to the receiver or from your BD player to the receiver.. doesn't matter which one you use.. both do the job just fine. It's when you don't hear anything that becomes a problem.
    if it bugs you switch it out.. i use both types of cables.. i can't tell the difference.. and both work as they should.
    PolkFest 2012, who's going>?
  • WilliamM2
    WilliamM2 Posts: 4,810
    They should work the same, but when you get a new reciever, get an HDMI cable to hook up the BD player. You won't get the HD audio codecs with optical or coax.
  • danger boy
    WilliamM2 wrote: »
    +1 good point. :)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I asked the same question not to long ago...someone posted up this page for me to read.
    http://www.6moons.com/audioreviews/toslink/toslink.html
    It's a pretty interesting read...what it really comes down to though is whichever sounds better in your ear. Neither one is really superior to the other. They both do the same thing, and they both do it well. You've just gotta get both, and test them out, and see what your preference is.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Eric W
    Eric W Posts: 556
    WilliamM2 wrote: »
    Yup. It's ok with an older receiver that doesn't have Dolby TruHD, Dolby Digital Plus or DTS Master Audio HD, but use the HDMI if you have any of the above.
    -Eric
    -Polk Audio
