M-200t Help
Farmboy8
Merry Christmas everyone.
How bout a little amp help.
I have noticed lately that my Carver m-200t is making a noise. It makes it when it is hooked up and when it has nothing hooked into it. The only way to describe it is to say that it sounds like a old tractor.
" Putt-putt-putt-putt-putt-putt."
John Deere green. Get it?:D
Any thoughts?
Any thoughts?
"The goddamn Germans got nothing to do with it":p
Denon 3802 (Reciever)
Polk audio Rti-8 (Fronts)
Polk audio Csi-3 (center)
Blue Ray Sony Bdp S550
LG 50" Plasma (1080P Smart 3D) (TV)
320 GB Xbox 360 (MW3 Edition) (Game)
Post edited by Farmboy8 on
Sounds like a case of old electrolytic caps, which need to be replaced in the power supply.
If you can't do it yourself, Bob Carver can do it for you!
http://www.carveraudio.com/phpBB3/viewtopic.php?f=4&t=7093Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Bonus Link Viper! Packin' up my 200t's and sending them out. I've been chasing ground loops thinking that was the problem:o Thanks!
Best of luck Farmboy and welcome to circus... -
Is this dangerous? Fire danger?The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Well, your sound definitely is deteriorated, since the filter caps are drying up.
For $170 USD + shipping, Bob/Rita will rework your entire amp, not just fix this problem. Also, if the filter caps will fail/short, you might end up with the dead amp.
My TFM-24 is going to them in the spring. They just (re)opened, so the line-up from Carver forum looks to be pretty long
. Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Thanks for all the help guys!! But one more question.. If I was going to do this myself where do I get the electrolytic caps and how do I put them in. Sorry I just cant bring myself to spending more on a amp than I payed if I can fix it myself. Thank you
Kevin"The goddamn Germans got nothing to do with it":p
320 GB Xbox 360 (MW3 Edition) (Game) -
"If I can fix it" being the key operative words here. These aren't your typical layout internally and should only be trusted to someone who has the gear to test things as they go. If you have the service manual, 'scopes, meters, etc.....knock yourself out. Good luck....Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
You definitely have to know what you are doing with these amps... but you can buy a service manual (check Carver forums for the sources), and the parts are available from most electronics retailers (digikey, mouser, etc.).
Make sure to do the proper diagnostics and tune up per the service manual too...Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
