Winter finally begins
I woke up an hour ago to it being 84 degrees in my apartment. I turned off the thermostat and the heat is still pumping. I took the thermostat off the wall and spread the two wires out away from each other and it's still pumping. It's now 87 in here. I sent a text message to the landlord.
oh wait it says 89 degrees in here!!!!
WOW a apartment with a Florida room....rent must be expensive!!
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro -
suns up and its now -12
keep our heat usually around 67-68 but today up to 70
good day to stay inside, warm and listen to tunes -
Just got in from blowing the driveway, yep -12 degrees and a good stiff breeze - that will cool you off in a hurry
Its in the 50s today. Much colder then the 70 degress we had the past 2 days.
I bet you really cant wait for your new house to close now :eek:
I dont know, wouldnt too much heat be easier to deal with where you guys live then if the heat petered out ? At least you can open windows to cool off...that heat goes all the way out and then you are really hurting.The first rule of Fight Club is you don't talk about Fight Club -
High of +31F here today. Got another inch of snow, added to the 4 inches we got on Friday. Calling for another 1-3" in scattered showers through the day. High temp tonight is supposed to be around +10f. Really wish I had gotten my new windows in this summer
. What I couldn't spend then for windows, I'll be spending now for heat. Ludicrous gibs! -
+54 degrees here right now....at 9:35:36 am ..just had a nice little 4.1 earthquake ( San Andreas fault about 300 feet behind my house ) to start the Sunday morning.
http://quake.wr.usgs.gov/recenteqs/Quakes/nc51213534.htm The first rule of Fight Club is you don't talk about Fight Club -
-6 with a -36 windchill...looking to stay around-30 to -40 windchills most all day..........
new snow in the driveway
Happy Holidays to all
We're in the same boat down here in IL today. -7 when I woke up with -30 wind chill. And for some reason, my damn dogs have had to go out way more than normal. I'm gonna install an indoor doggy toilet or something. This sucks.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Winter started 3weeks ago here, as soon as snow stays on the ground!
Chances are the zone valve controlling your apt is stuck open. We finally got our first cold spell here starting saturday it's -36 out at the moment the expected high for wednesday is -40.I woke up an hour ago to it being 84 degrees in my apartment. I turned off the thermostat and the heat is still pumping. I took the thermostat off the wall and spread the two wires out away from each other and it's still pumping. It's now 87 in here. I sent a text message to the landlord.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
