Polk Audio Monitor 40 or RTi4 Bookshelves?
javygonx
javygonx Posts: 70
edited December 2008 in Speakers
Hi:
I currently have RTia7 for front speakers. I have 2 Infinity Bookshelf for surrounds, but I want to upgrade surrounds. Not sure if Monitor 40 or RTi4.
I know RTi4 are real wood, and better construction, but Monitor's 40 has 2 woofers. Anyway Im looking for better quality sound. Can't afford more that $200, the other RTiA1, RTiA3 are way expensive. Any recommendations?
Panasonic 65" Plasma
Pioneer SC81
PS4 BluRay / Memorex BD-Player
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner
Post edited by javygonx on
  • curved
    curved Posts: 664
    Get the RTi4's
    And what do you have for your center?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • Eric W
    Eric W Posts: 556
    RTi4 (or FXi series) FTW! Monitor 40 is from a different series completely and is not as easily wall mountable. RTi4 has integral keyhole slot on the back. Just screw into a stud and hang up the speaker if you need to wall mount.
    -Eric
    -Polk Audio
  • comfortablycurt
    comfortablycurt Posts: 6,745
    RTi 4 all the way. They will blow those Monitor 40's out of the water.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Erik Tracy
    Erik Tracy Posts: 4,673
    RTi4s!
    Sweet little bookshelf with lots of sonic goodness!
  • javygonx
    javygonx Posts: 70
    Erik Tracy wrote: »
    RTi4s!
    Thanks to all. Great.. someone asked me what I have for Center..
    Ok, dont get mad, people, but I have CS2. Bought it new for $89.
    Pioneer SC81
    Polk RTiA7 Fronts
    Polk CS2 Center
    Polk RTi4 Surrounds
    Eomtiva XRef12
