Polk Audio Monitor 40 or RTi4 Bookshelves?
Hi:
I currently have RTia7 for front speakers. I have 2 Infinity Bookshelf for surrounds, but I want to upgrade surrounds. Not sure if Monitor 40 or RTi4.
I know RTi4 are real wood, and better construction, but Monitor's 40 has 2 woofers. Anyway Im looking for better quality sound. Can't afford more that $200, the other RTiA1, RTiA3 are way expensive. Any recommendations?
Panasonic 65" Plasma
Pioneer SC81
PS4 BluRay / Memorex BD-Player
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Post edited by javygonx on
Get the RTi4's
And what do you have for your center?Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
RTi4 (or FXi series) FTW! Monitor 40 is from a different series completely and is not as easily wall mountable. RTi4 has integral keyhole slot on the back. Just screw into a stud and hang up the speaker if you need to wall mount.-Eric
-Polk Audio -
RTi 4 all the way. They will blow those Monitor 40's out of the water.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
RTi4s!
Sweet little bookshelf with lots of sonic goodness!
Erik Tracy wrote: »RTi4s!
Thanks to all. Great.. someone asked me what I have for Center..
Ok, dont get mad, people, but I have CS2. Bought it new for $89.Panasonic 65" Plasma
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
