Electrical outlet advice needed
NJPOLKER
I am planning on having a electrician install a dedicated outlet for my new amp. The breaker box is about 20 feet away so that should be simple. I am going to remove the paneling and put up sheet rock soon so thats no problem.
Do I just have him run a separate 20 amp breaker with a line to the outlet? Do I have to use a special outlet?
Do I only plug the amp into that line?
Alot of Do I's there LOL
I hope I'm on the right track.
Drew
Drew
Post edited by NJPOLKER on
You would have a 20amp breaker, 20amp wire 12/2 with a 20amp outlet. The 20amp outlet can receive both 15amp or 20amp AC cords. You don't need a special output but you can replace it with a nice outlet later
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Dude seriously have him wire 2 circuits at 20 amps. The price difference is next to nothing. I just did one for Early B.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Since you've plan to do the dedicated audio power line, why not install power port?
http://www.psaudio.com/ps/products/detail/power-port?cat=accessories
And also, do two separate 20A lines, for future expansion, while you're at it. I would and I did. The second line is used to feed the subwoofer. YMMV.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Yes not that hard just tell him you need 1 or 2 (your choice but maybe what Ben stated cheap to add another one) 20 amp outlet(s). He should know it requires 12g wire and 20 amp breaker / fuse.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I think you'll need 12/3 wire for two outlets.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Hi,
Because it is so easy now, have one for digital gear, one for analog, and one for the amps and one or two (switched and unswitched) for lights. Then you will never wish for another!Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
i was planning om having 1 installed in the very near feature, but you guys just convinced to go for 2 instead!
+1 on two circuits.____________________
Pool: Atrium 60's/45's
