Electrical outlet advice needed
NJPOLKER
NJPOLKER Posts: 3,475
edited December 2008 in DIY, Mods & Tweaks
I am planning on having a electrician install a dedicated outlet for my new amp. The breaker box is about 20 feet away so that should be simple. I am going to remove the paneling and put up sheet rock soon so thats no problem.
Do I just have him run a separate 20 amp breaker with a line to the outlet? Do I have to use a special outlet?
Do I only plug the amp into that line?
Alot of Do I's there LOL
I hope I'm on the right track. :o
Drew
Post edited by NJPOLKER on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    You would have a 20amp breaker, 20amp wire 12/2 with a 20amp outlet. The 20amp outlet can receive both 15amp or 20amp AC cords. You don't need a special output but you can replace it with a nice outlet later ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • ben62670
    ben62670 Posts: 15,969
    Dude seriously have him wire 2 circuits at 20 amps. The price difference is next to nothing. I just did one for Early B.
    Ben
  • polkatese
    polkatese Posts: 6,767
    Since you've plan to do the dedicated audio power line, why not install power port?
    http://www.psaudio.com/ps/products/detail/power-port?cat=accessories
    And also, do two separate 20A lines, for future expansion, while you're at it. I would and I did. The second line is used to feed the subwoofer. YMMV.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • disneyjoe7
    Yes not that hard just tell him you need 1 or 2 (your choice but maybe what Ben stated cheap to add another one) 20 amp outlet(s). He should know it requires 12g wire and 20 amp breaker / fuse.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Early B.
    Early B. Posts: 7,900
    I think you'll need 12/3 wire for two outlets.
    "God grooves with tubes."
  • bikerboy
    bikerboy Posts: 1,235
    Hi,
    Because it is so easy now, have one for digital gear, one for analog, and one for the amps and one or two (switched and unswitched) for lights. Then you will never wish for another!
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • acsubie
    acsubie Posts: 773
    i was planning om having 1 installed in the very near feature, but you guys just convinced to go for 2 instead!
  • mmadden28
    mmadden28 Posts: 4,283
    +1 on two circuits.
    ____________________
    Pool: Atrium 60's/45's
