Is this a good deal?
michaeljhsda2
michaeljhsda2 Posts: 2,201
edited December 2008 in Vintage Speakers
Found this on my local CL. Is this a good deal?
http://stlouis.craigslist.org/ele/948025396.html
Mike
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
  • George Grand
    George Grand Posts: 12,256
    If you have to ask, you don't deserve them.
  • danger boy
    danger boy Posts: 15,722
    that price is about 1/3 of what they normally go for... so you decide if it's a good deal :p
    run don't walk. ;)
    PolkFest 2012, who's going>?
  • michaeljhsda2
    I'm on it...thanks
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    What model are these? 10's? I'm second in line if the first guy doesn't buy them.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Poee7R
    Poee7R Posts: 906
    Yep sure are. Looks to be a set with Peerless tweeter's also.
    Do what ya can to getem, great deal.
    Dave
    Once again we meet at last.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Great deal, run and go get them.
  • average_guy
    average_guy Posts: 236
    There has been a pair of these on my local CL for $250 in the recent past; $50 is the proverbial no-brainer.
  • michaeljhsda2
    Bought em'. :D The seller said he had a bunch of inquires but nobody would show up to check them out. Looks like they are in good condition, however, one dead tweeter. I swapped fuses to see if that was the issue. Nope. Still dead. I'm gonna swap out the other tweeter and see if works in the other speaker.... I removed the tweeter and noticed that the leads are soldered. This will take a few more minutes to get the answer. If the tweeter is dead, anybody know where I can get a replacement or anbody got a spare Peerless you're looking to sell? Thanks for the input guys.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • danger boy
    their loss is your big gain. congrats.. those are very nice looking Mon 10A's. Peerless and all. even with one dead tweeter. you still made out for well below going rate.
    :D
  • beardog03
    beardog03 Posts: 5,550
    no send them to me !!
    I will fix them and enjoy them for awhile , then send them back at a later date !!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • michaeljhsda2
    danger boy wrote: »
    :D
    thanks. Now for the desoldering....update in awhile.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Swapped the tweeter with the other good one and still no HF. Xover?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Probably not
    The past owner clipped his receiver and blew the tweeter.
    Look on e-bay for Peerless Tweeters or put an add in the wanted section here and maybe a fellow Polk Member has one for you.
    Drew
  • michaeljhsda2
    NJPOLKER wrote: »
    Probably not
    Drew
    But when I put the good tweeter in the speaker cabinet that has the problem the good tweeter no longer works.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thsmith
    thsmith Posts: 6,082
    So does the tweeter that was none functioning work in the other cabinet?
    Looks like you may need to start tracing wires looking for broken solder or componets on the XO I would think.
    At least verify continunity for the tweeter speakers leads. COuld be as simple as broken lead.
    Good luck and a very nice deal, congrats.
    There was a fair looking pair of SDA 1s in your area. Guy has had them posted for about 6 weeks. I think the dust cone is pushed in on a couple drivers and the hardwood needs to be spruced up.
  • michaeljhsda2
    thsmith wrote: »
    Thanks. No, the tweeter in question doesn't work in the other functioning cabinet either.
    Those are the SDA1's that I posted about in CP. Here's the link I started last month. http://www.polkaudio.com/forums/showthread.php?t=73836
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • danger boy
  • thsmith
    Mike
    Sounds like the one speaker has several problems, 1 bad tweeter and something else
    Is the Stereo and Dimentional drivers work with and without IC?
  • Poee7R
    Poee7R Posts: 906
    They look great.
    At the price you got them for, I would think if you sent the x-over's to Ben and had them updated, you would still be in the positive on them. They wouldn't require Mcaps or the such, but I bet some Solens or Dayton's would work wonders. Which would probably give you better sound than stock and you would have the peace of mind of having a x-over rebuilt with all new parts (if indeed is it a x-over related issue).
    The Peerless tweet's show up on ebay here and there, grab a pair if you can so you have a spare. Or just order some silk dome replacement's, which may be blasphemous, depending on who you ask. :p
    Good score.
    Dave
  • michaeljhsda2
    thsmith wrote: »
    I'm buying another tweeter from a CP member, plus it's due for new caps and resistors anyway so I'll redo those as well.
    As far as your IC question, are you referring to the SDA 1C's for sale? If so, the dimensionals won't work without the IC connected.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Poee7R wrote: »
    They look great.
    Good score.
    Thanks Dave, the speakers are in really good condition and to think, several calls about them and no one shows up to check them out! Xover upgrade is definitely in the plans.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    thsmith wrote: »
    "At least verify continunity for the tweeter speakers leads. COuld be as simple as broken lead."
    I got 3.4 ohms on the VM.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Speaker now works when I installed an RDO 194 tweeter. Replacement peerless on the way.
    SDA SRS 2.3TL's
    SDA 2B TL's
