Is this a good deal?
michaeljhsda2
Found this on my local CL. Is this a good deal?
http://stlouis.craigslist.org/ele/948025396.html
Mike
Mike
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
If you have to ask, you don't deserve them.
that price is about 1/3 of what they normally go for... so you decide if it's a good deal
run don't walk.
PolkFest 2012, who's going>?
I'm on it...thanksSDA SRS 2.3TL's
SDA 2B TL's -
What model are these? 10's? I'm second in line if the first guy doesn't buy them.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »What model are these? 10's? I'm second in line if the first guy doesn't buy them.
Yep sure are. Looks to be a set with Peerless tweeter's also.
Do what ya can to getem, great deal.
DaveOnce again we meet at last. -
Great deal, run and go get them.
There has been a pair of these on my local CL for $250 in the recent past; $50 is the proverbial no-brainer.
Bought em'.
The seller said he had a bunch of inquires but nobody would show up to check them out. Looks like they are in good condition, however, one dead tweeter. I swapped fuses to see if that was the issue. Nope. Still dead. I'm gonna swap out the other tweeter and see if works in the other speaker.... I removed the tweeter and noticed that the leads are soldered. This will take a few more minutes to get the answer. If the tweeter is dead, anybody know where I can get a replacement or anbody got a spare Peerless you're looking to sell? Thanks for the input guys.
MikeSDA SRS 2.3TL's
SDA 2B TL's -
their loss is your big gain. congrats.. those are very nice looking Mon 10A's. Peerless and all. even with one dead tweeter. you still made out for well below going rate.
no send them to me !!
I will fix them and enjoy them for awhile , then send them back at a later date !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
danger boy wrote: »their loss is your big gain. congrats.. those are very nice looking Mon 10A's. Peerless and all. even with one dead tweeter. you still made out for well below going rate.
thanks. Now for the desoldering....update in awhile.
MikeSDA SRS 2.3TL's
SDA 2B TL's -
Swapped the tweeter with the other good one and still no HF. Xover?SDA SRS 2.3TL's
SDA 2B TL's -
Probably not
The past owner clipped his receiver and blew the tweeter.
Look on e-bay for Peerless Tweeters or put an add in the wanted section here and maybe a fellow Polk Member has one for you.
Drew -
Probably not
Drew
But when I put the good tweeter in the speaker cabinet that has the problem the good tweeter no longer works.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »But when I put the good tweeter in the speaker cabinet that has the problem the good tweeter no longer works.
So does the tweeter that was none functioning work in the other cabinet?
Looks like you may need to start tracing wires looking for broken solder or componets on the XO I would think.
At least verify continunity for the tweeter speakers leads. COuld be as simple as broken lead.
Good luck and a very nice deal, congrats.
There was a fair looking pair of SDA 1s in your area. Guy has had them posted for about 6 weeks. I think the dust cone is pushed in on a couple drivers and the hardwood needs to be spruced up.Speakers: SDA-1C (most all the goodies)
Thanks. No, the tweeter in question doesn't work in the other functioning cabinet either.
Those are the SDA1's that I posted about in CP. Here's the link I started last month. http://www.polkaudio.com/forums/showthread.php?t=73836
MikeSDA SRS 2.3TL's
SDA 2B TL's -
.............PolkFest 2012, who's going>?
michaeljhsda2 wrote: »Thanks. No, the tweeter in question doesn't work in the other functioning cabinet either.
Mike
Sounds like the one speaker has several problems, 1 bad tweeter and something else
Is the Stereo and Dimentional drivers work with and without IC?Speakers: SDA-1C (most all the goodies)
They look great.
At the price you got them for, I would think if you sent the x-over's to Ben and had them updated, you would still be in the positive on them. They wouldn't require Mcaps or the such, but I bet some Solens or Dayton's would work wonders. Which would probably give you better sound than stock and you would have the peace of mind of having a x-over rebuilt with all new parts (if indeed is it a x-over related issue).
The Peerless tweet's show up on ebay here and there, grab a pair if you can so you have a spare. Or just order some silk dome replacement's, which may be blasphemous, depending on who you ask.
Good score.
I'm buying another tweeter from a CP member, plus it's due for new caps and resistors anyway so I'll redo those as well.
As far as your IC question, are you referring to the SDA 1C's for sale? If so, the dimensionals won't work without the IC connected.SDA SRS 2.3TL's
SDA 2B TL's -
They look great.
Good score.
Thanks Dave, the speakers are in really good condition and to think, several calls about them and no one shows up to check them out! Xover upgrade is definitely in the plans.
MikeSDA SRS 2.3TL's
SDA 2B TL's -
"At least verify continunity for the tweeter speakers leads. COuld be as simple as broken lead."
I got 3.4 ohms on the VM.SDA SRS 2.3TL's
SDA 2B TL's -
Speaker now works when I installed an RDO 194 tweeter. Replacement peerless on the way.SDA SRS 2.3TL's
SDA 2B TL's
