Integra vs Onkyo - What's the difference?
math wizard
math wizard Posts: 106
edited December 2008 in Electronics
I've been looking at Integra and Onkyo receivers. Are they the same with just a diff. look and name so that they can be sold through diff. sales channels (similar to what Yamaha, Denon, Pioneer, etc... does)? The Integra 7.9 and the Onkyo 805/875 look strangley similar spec. wise. Could someone comment?
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
Post edited by math wizard on
  • mantis
    mantis Posts: 17,380
    Integra is made for Custom Install. Onkyo is the standard. Think of Integra as Elite of Pioneer. better built quality, better power supplies, Bigger caps , better chassis.
    When I worked for a onkyo/Integra dealer (Soundex) this is what I learned there. Both products are fantastic but the Integra line is the ELite. It's not a rebadged Onkyo receiver.
    Dan
    Dan
  • MikeC78
    MikeC78 Posts: 2,315
    Onkyo makes a Pro series also, I believe they are similiar to the Integra line. I seen some internal pics over at AVS with the Pro and the Integra side by side, and the Pro line had the exact same power supplies labled as Integra on it. The only difference was the facia. I believe they were comparing the newer Pre's, the 9.8 and the 998.
  • WilliamM2
    WilliamM2 Posts: 4,807
    mantis wrote: »
    Dan
    That may have been true at one time, but no longer. The current Onkyo and Integra units are identical. My Onkyo 885 even had "Custom designed for Integra" written on the toroidal transformer.
  • Sherardp
    Sherardp Posts: 8,038
    Integra is also harder to get or should I say harder to find in personal experience.
  • mantis
    WilliamM2 wrote: »
    If Onkyo and Integra is now the same, why spend the money and put out 2 lines??? Makes no sense. We are picking up Integra and I will question our rep. He is coming in soon. I will report back what he tells me.
    Dan
    Dan
  • apphd
    apphd Posts: 1,514
    WilliamM2 wrote: »
    mantis wrote: »
    Dan
    I would bet it is just a cost effective way to manufacture. Sharing some parts would not make them identical. Also willing to bet that there are other parts shared as well. Just like some parts in a Lexus are the same as can be found in a Toyota. Quantity buying power, reduced engineering costs, reduced wharehousing and material management costs (some factory may be cranking out Onk and Integra models right side by side, is the major factor in this.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    apphd wrote: »
    Just like some parts in a Lexus are the same as can be found in a Toyota....
    and Pontiac.
  • mmadden28
    mmadden28 Posts: 4,283
    Huh, I always thought the difference was that the Integra's had no amp, and had extra features made for custom installations such as balanced outputs, etc.
    I also figured they were harder to get/find as they were only available though custom installers or the used market, not the regular retail market.
    Interesting discussion.
    ____________________
    Pool: Atrium 60's/45's
  • MikeC78
    mantis wrote: »
    Dan
    Have no idea why they put out the two lines really? The only difference is mainly the looks of it. Go check out the new Onkyo Pro 886 and the Integra 9.9. The inards are reported identical over at AVS, and actually the Onkyo is more expensive than the Integra by like $50. I believe the difference in cost is the rack ears on the 886 that the Integra lacks.
  • WilliamM2
    mantis wrote: »
    Dan
    They spent years building up the Integra name, why not have models under each brand? It gives the custom installers a different product than the big box stores sell. It's called marketing.
    Rather than ask a rep, do what I and others have done. Open up an Onkyo 885 and an Integra 9.8, see if you can find a single part that is different, other than the face plate.
    Oddly enough, the Onkyo had a higher list price in this case, and a feature or two that are missing on the Integra. Hardware is identical.
  • mmadden28
    Its like a Chevy Blazer and a GMC Jimmy Same cars right?
  • Serendipity
    Serendipity Posts: 6,975
    WilliamM2 wrote: »
    I believe the two units are identical.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    The way I understood it is that the Onkyo's are produced on an assembly line, where as the Integra's are hand made, to stricter tolerances.
    I've been wondering the same thing though...I've looked at both, and they appear to be essentially identical.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
