Denon AVR-2809CI, Polk RTIA9 & CSIA6 good?
astrodanco
astrodanco Posts: 2
edited December 2008 in Speakers
I have purchased a Denon AVR-2809CI for 80% home theater and 20% light rock music listening in my 18ft X 25ft (or so) vaulted ceiling living room.
I'd like to get some reasonably good speakers. My budget is very limited.
I'm thinking of picking up a pair of Polk RTIA9s (about $1000 for the pair) for the fronts and a Polk CSIA6 (about $450) for the center. Would these work well with the 2809? If not, any recommendations?
Any recommendations on a good sub-woofer for under $500?
I'll get some appropriate surrounds later.
Post edited by astrodanco on
  • thsmith
    thsmith Posts: 6,082
    astrodanco wrote: »
    The AVR is great but those speakers will need more power to get best performance. You could add a Carver or like 225wpc for just the mains, your denon has pre-outs.
    What is the cubic feet of your room before a solid recommendation can be made for a sub. A $500 may be a waste of money unless you planned to add a second in the future (if your room is large).
    My personal recommendation is HSU or SVS as that is what I experience with.
    Knowing your room size will help with recommendations
  • mantis
    mantis Posts: 17,327
    I don't think so. The Denon has plenty of power to drive those speakers. You will be fine.
    Congrads on your new system,
    Dan
    Dan
  • thsmith
    mantis wrote: »
    Dan
    Agree the Denon will play them find but to get the best sound out those speakers more power will allow them to perform best.
  • astrodanco
    astrodanco Posts: 2
    The I think the room is about 4200 cubic feet.
    I can buy a separate amp at a future date. But I honestly don't plan on turning the volume up very loud. It's a rare occasion that my wife will let me do that. The neighbors might complain as well.
    Maybe I'd be better off with a pair of Monitor 70s?
  • trinidesignz
    trinidesignz Posts: 97
    I think you should try a step down the RTi A7's if you not going to take those BadBoys and push him. But at the price you got them for geeeezeeeee Keep them.:D
    Samsung-55 LED
    Denon 3808ci
    RTi A5 (Fronts)
    CSi A6 (Center)
    FXi 5 (Rears)
    Velodyne DPS-12 (Sub)
    EMOTIVA XPA-5 :D:cool::p;):)
  • Upstatemax
    Upstatemax Posts: 2,735
    I have my Denon 2808 hooked up to my Monitor 70's (Bi-Amped) and I am very happy with them.
    However, I would have LOVED to be able to get my fingers on a set of RTi A9's... On the other side, if you are not going to be able to crank them and really enjoy them, I would go with the A7's since they are far less power hungry.
    As for the sub, my father just picked up a Mirage Prestige S10 for $400 (original $800) and that thing is NICE.
