Changes
halo
After moving my beloved InnerSound Eros and associated components I combined what I had left and what I was allowed to borrow from my brother as well as a felow Pokie to make the best of a bad situation.
I am very thankful and appreciative to those that are helping me out (that includes anyone and everyone who is pulling for me right now
So here's what I've got now: LINK
The Von Schweikert VR-2's are on loan from my brother (I forgot how good these speakers sound!)
They are driven by the Sanders Sound System ESL amp running through the Multi Room input on the HK. I use the SB3 (inhereted / on loan) with a CIAUDIO PS as the source for the 2 channel.
I consolidated two racks into one so I now have more room to maneuver around plus the VR-2's fit nicely next to the rack.
The SVS used to be behind the TV & now it's on the opposite wall / corner. Still playing w/ the config on the SVS.
The result is a much cleaner and open room with better than expexted sound quality. The VR-2's dig deep but not as deep as the Eros. (I did A / B them when I still had the Eros). They aren't as holographic as the Eros but they do very well for a convential speaker. Maybe its due to that driver on the rear of the VR-2's.
Just wanted to let everybody know what's new with me and to again thank everyone for their support.
Post edited by halo on
Looks great. Nice TV. I have the same one.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I liked the VR-2's better than the LSi15's when we did that shoot out at Mike's last year. Great speakers. I bet they sound good with that set up._________________________________________________
I thought the VR-2's were fantastic also! Nice looking setup. Hang in there! Remember that what doesn't kill you only makes you stronger!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Looks great!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Nice clean setup Victor! What do you think about the Bolder Statement SB3? Norm and I felt the most amusing ModWright Sony 9100 was leaps and bounds better, but you aint slumming with the modded SB3. Not a loan, call it right of first refusal should you decide to part with it.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Thanks Rich
& will do
I like the SB3 very much. The sound quality is surprisingly good - I don't think it has all the detail, resolution, and fullness that the 9100 has but, like both of you pointed out, the convenience is off the charts.
This rig is on a different wall than the Eros rig, and the only component they have in common is the Sanders amp. Also there are no tubes in this rig where as I a tube pre & a tube CDP w/ tube rectified PS w/ the Eros. I suppose this can be seen as "a step back" from what I had but truth be told I hadn't listened to the Eros much since April so I'm kind of starting off "fresh".
Since the SB3 has all my music @ my fingertips I am listening to a lot more music since this rig got set up. Granted I'd ripped my library to an external HD (WAV format), about a year ago when I tried a stock SB3 & it is a major PITA to do that so you can enjoy the simplicity later. There are a few quirks w/ the SB3 but it's nothing I can't live with. There is no comparison between a stock unit w/ the stock PS and the Boulder Cable modified unit w/ CIAUDIO PS.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
You've had quite an audio journey Victor. I hope things go better for you in 2009. Best of luck;)Carl
Thanks Carl!
I think things have a way of working themselves out - it just goes faster when we take an active roll.
Maybe I shoulda bought the AL III's from ya
I'm greatly relieved to see you've got a rig up and running. I guess I should have known you wouldn't be without.
President of Club Polk -
Thanks Jesse
The SB3 is addictive and my return is due in large part to it.
Amazing to come full circle like this.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Hey everybody. 2009 was fine but 2010 is off to a rocky start thanks to you know who.
The TV bit the dust, sort of. It's not functioning properly anymore.
The SB3 is all fouled up as well.
would appreciate your thoughts & prayers here.
Have you updated the firmware on the SB?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
yes I haveHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Thoughts and prayers sent.
Did the SB3 mess up *after* you dl'd the new firmware? I just did that and had to go in and reconfigure all the settings. The web interface is sightly different as well and takes some getting used to and you need to rescan your library. The SB forums are really helpful, but it's still a slight PITA to reconfigure your settings.
Good luck Victor
Thanks Brock.
IMO, the SB3 is like a temperamental child. Always acting up.
It is back on line after a reboot of the PC but the settings are all wonky. Most albums don't play in order any more and I don't have random or shuffle engaged - the song list on most albums plays alphabetically now instead of in the order they were in on the CD - I changed nothing so I can't wrap my head around how it happened. No idea how to get it back because it isn't consistent with all the albums. 90% sure they were all ripped the same way but that was a long time ago. lol.
Hope your doing well too buddy! Thanks again
Well, like I said if you downloaded the new software version then that's most likely your issue. A suggestion for next time is to write down all your previous settings before downloading so you can set the new version up with the same custom settings.
The thing with the new software upgrade is, it's completely new as in it unistalls the old version and then installs a completely new version. It's not just an update of the old version. I have a SB2 and have had zero issues with it (other than my boneheaded tagging errors) until I downloaded the new Squeeze Center software and realized I had to go back and customize it. One thing that must be done is deleting your library from the Squeeze Center database and then re-scanning. I like the new interface but it's a little different and you really have to start over with all your settings.
**NOTE** do not choose to delete completely because you'll loose all your music as it deletes it from the hard drive. If that happens you can always do a system restore to an earlier day in the week.
Looks great.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
