B. Joel-Innocent Man SACD Issue
anton.chigurh
I appear to have gotten a crappy, low quality SACD.
Picked this up off eBay for $15. On all but 2 or 3 tracks, the vocals come strictly through the surrounds as an extremely faint echo. The rest of the music comes through loud and clear on the other speakers.
While the mix seems a little weird on the other 2 or 3 tracks, they sound okay.
No such issues with my other SACDs and DVD-A.
Anybody ever have any issues like this? They can't all be this bad, but is this normally a well mixed, good sounding SACD?
Post edited by anton.chigurh on
If this is normal, then I don't know what's the big fuss about SACD..
I ran into a couple DVD-A in the past, that exhibited similar crappy mixed. Can't say have seen it on my SACD collections. Email the record label and ask the question. I did that one time, and they sent me a replacement) which unfortunately has the same crappy mixed. oh, well.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
It's not normal. That much I can tell you.If this is normal, then I don't know what's the big fuss about SACD..
I haven't heard that CD in quite a long time but I do seem to recall that it wasn't the best of recordings to begin with. If I'm wrong, forgive me but if I'm right there is nothing that can make chicken soup out of chicken ****.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
The big fuss about SACD was as a high-resolution two-channel digital format, addressing some of the profound limitations of the original "redbook" CD (e.g., low resolution; the 'brick wall' at 20 kHz). Even Sony, in so many words, has said of SACD "now it's almost as good as analog on vinyl". :-) -
My copy sounds good. Check your settings on your sacd player.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
I figure I just got a bunk copy. No issues with my others.
I can always do some skeet shooting with it.
Thanks guys. -
Did you by chance purchase this at Wal-Mart or Sam's Club?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Got it off eBay and meant to make an issue out of it, the got side tracked and never dealt with it.
BTW....it's actually "The Stranger" not "Innocent Man". Put it in again last night...half the songs are basically instrumentals...the others sound good. -
BTW....it's actually "The Stranger" not "Innocent Man". Put it in again last night...half the songs are basically instrumentals...the others sound good.I have this on SACD and it sounds nothing short of.... great. Strictly in 2 Channel so I can't comment on the surround aspect. I have it playing now, and have to say it sounds like it should. (Denon DVD 3910 is the player)
I do have a Elton John SACD that won't load and play, no matter how much swearing and threatening I do.Home Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!!
