Free horns on Audio Asylum classified
gidrah
gidrah Posts: 3,050
edited June 2003 in Flea Market
These look pretty interesting and are free for an E-mail (to them, not me). They should go great with any of Polk's tweeters. I sent them an E-mail and they replied saying mine would be sent.http://java.audioasylum.com/ca/ad.jtp?ad=2260
Make it Funky! :)
Post edited by gidrah on
  • faster100
    faster100 Posts: 6,124
    edited June 2003
    sure this isn't just a cheap way of obtaining many addresses and sending junk mail??
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    I'm not sure of anything. Maybe it is, but I get enough junk now that a little more won't hurt. I think they're just trying to do some advertising as I'd never heard of them before.
    Make it Funky! :)
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    Hell I sent for a pair why not.....like gidrah said what's a little more junk mail .I would definately prefer some audio junk mail over some of the other crap I get.
    Stuff.
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
  • Ceruleance
    Ceruleance Posts: 991
    edited June 2003
    I also got a pair, why the hell not? I doubt they use the names for junk mail, although they might, I think they just want you to try the product. Besides, it seems as if you like what it does for your tweeters, you will need to buy a set of the larger cones for your mids /woofers in order to balance out with the now more directional/higher output tweeter. That'll set you back $80.
    It's a shame they are so ugly. Maybe if someone likes them they can make a DIY enclosure with them built flush into the cabinet.
  • jrausch
    jrausch Posts: 510
    edited June 2003
    Say goodbye to your imaging. Horns don't image because the sound is focused through the guide. Calling Dr. Susse. I don't even want to touch those things.
    "The only way to get rid of a temptation is to yield to it."
  • rs159
    rs159 Posts: 1,027
    edited June 2003
    WTH?
    So basically you take your regular speakers and put horns on them. "One size fits all", and you hope it sounds good. Hmmm....
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2003
    Thanks Mark, great link.
    Have a pair coming here, and a pair to my mom's house. Don't expect many here to understand horn technology, either internal or external relative to the speaker cab.
    Can't wait to test on all the 2ch rigs, esp on SDA.
    I've never heard of horns smearing/fubaring an image, if anything, it should create a more direct image, granted - smaller sweet spot more than likely, but hell, to dismiss it outright, when it's free?
    -Russ
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    You're more than welcome. You're right it's free and is atleast worth a shot. If they don't work, send 'em on to me. I'm gonna be working on some arrays anyways.
    Horns don't muck up anything. They get a bad rap because they are most often used with compression drivers that have cheap diaphrams. Sure they limit the size of your sweet-spot, but they'll also limit the defractions. This is what diffusers and the LSi tweet are based upon.
    Make it Funky! :)
  • rs159
    rs159 Posts: 1,027
    edited June 2003
    Originally posted by gidrah
    ...Horns don't muck up anything. They get a bad rap because they are most often used with compression drivers that have cheap diaphrams. ...
    Don't forget the speakers at the race track and the coach's megaphone :D
  • RuSsMaN
    edited June 2003
    ..pay attention Rs..
  • TonyPTX
    TonyPTX Posts: 545
    edited June 2003
    I've seen enough of these to know....more **** on the way for you guys...besides who wants to glue these rings to their speakers?
    Damn....8 lines...I've gotta put my sig on a diet now....
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    Mine got delivered today. Silver colored plastic. The horn and mounting rings. The rings also have 3 pieces of velcro attached. They look pretty cool and cheap.
    Make it Funky! :)
  • Ceruleance
    edited June 2003
    no gluing, hell no would i glue. and its my parents house, anyways ;o)
  • madmax
    madmax Posts: 12,434
    edited June 2003
    I emailed for a pair. Price sounded reasonable to me.
    madmax
    Vinyl, the final frontier...
  • hotwheelman
    hotwheelman Posts: 1,300
    edited June 2003
    I used to have a pair of klipsch kg2 with a horn tweeter and the diaphram was actually a soft dome tweeter and the sound out of these things was nothing short of awsome. I think that I will get a pair of those to play around with.:D
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • rs159
    rs159 Posts: 1,027
    edited June 2003
    DIY flush mount em..... that'd be cool lookin. If you can find the right drivers and tweets they'll probably sound great.
    "Better than a $10000 upgrade" is a stretch in 95% of the cases though IMHO.
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    To say the least! Maybe if you spent that $10K upgrading your aamps, pre, source, & wire to drive a "pair of sun soaked Kracos" (golden qoute) yeah sure.
    As it is, they may be gone. I got mine, but some haven't gotten a reply. They're pretty cool, but just a piece of molded plastic. They're metal flake silver. The velcro makes them easy to attach to any dome tweeter. I can't see the price they're asking. Then again if these work I might invest in a pair of 4"ers for the periscopes.
    Good luck guys!
    Make it Funky! :)
    VR3 Posts: 29,700
    edited June 2003
    WAAAAAAAAAAA, So these dude want me to attach velcro to my speaker to attach a horn? Are they on crack? Gidrah, tell us how they sound! lol!
  • hotwheelman
    edited June 2003
    They are sending me some, I am going to play mad scientist with them on the garage system.:D
  • Tour2ma
    Tour2ma Posts: 10,177
    edited June 2003
    -Russ
    Russ,
    Have a link or a minute to post the basic theory? Best I can remember external horns were about focussing the sound energy. Effect was somewhat akin to nearfield or "close" listening. I can't ever remember seeing anything on interal horns. Enquiring minds want to know...
    Don't see the SDA application, however, as horns required the speakers to be toed in as I recall... yes?
    Anyways, I'm interested in the reviews of all the intrepid explorers above, although since the offers are only for 1" tubes I'm not sure the high frequency focussing will be all that enjoyable. Dome tweeters were a serious breakthrough for their ability to disperse highs...
    More later,
    Tour...
    Vox Copuli
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    http://www.melhuish.org/audio/horn.htm
    Those gumby looking speakers awhile back a were rear loaded (internal to cabinet) design.
    Make it Funky! :)
  • Tour2ma
    edited June 2003
    Nice link to add to the reference fav's... thanks, gidrah...
    More later,
    Tour...
    Vox Copuli
  • faster100
    edited June 2003
    i got em this morning.... now.. do i want velcro tape on my rti70's?
    lol
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited June 2003
    and....................
    also thier plastic with velcro both parts.. one attached to the horn and removable backing and sticky velcro to attach to the tweet
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • TonyPTX
    TonyPTX Posts: 545
    edited June 2003
    This is absolutely the worst looking thing I've ever seen as far as fasteners are concerned.... They should have provided some sort of speaker ring where you could install these via sandwiching them between the speaker and the cabinet. Cheap velcro is just gonna make hell for vibrational issues. OK all you folks who ordered these things,
    WHO IS ACTUALLY GONNA STICK THESE THINGS TO THEIR POLK SPEAKERS? :confused:
    Just a show of hands?
    Looks like they make some cool bases for some new speaker stands though :D
    Tony
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    The velcro is not necessary, but it is handy for testing purposes. There is a detachable ring at the bottom that can be glued or screwed in for a more permanent attachment.
    Make it Funky! :)
  • faster100
    edited June 2003
    see this is where i have a problem, **** or glueing stuff to my $400.00 speaker.. i just used tape 2 small pieces and when i just took them off some black came with it, didn't leave marks or anything, but i can say i "won't" be velcroing or **** anything to my 70's.. anyways.. the grill wont fit on even with the horn removed and the base plate installed.. what good is that.. ?
    The Mi-horn site has a stoneage description of putting screws through the grill material and mounting these free horns to your fabric, nah.. i will pass. I did test them today and i couldn't tell a "big" difference. not enough to canabalize my speaks anyway.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Tour2ma
    edited June 2003
    :D... I was thinking more along the lines of something left over from Madonna's last tour... :)
    Thanks for the review faster... So did the supplier include any kind of feedback form or link?
    More later,
    Tour...
    Vox Copuli
  • faster100
    edited June 2003
    heres the paperwork
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Tour2ma
    edited June 2003
    Thanks...
    Not even interested in feedback... wow.
    Can you say, "Loss Leader?".... I knew you could... :)
    More later,
    Tour...
    Vox Copuli
