Polk RTi10 tweeks
Peter Fleming
Hi Guys, I was just curious if any of you out there had modified your RTi10 speakers to open up the midrange and mellow the top end slightly. I'm not happy with mine, and looking at either modifying or selling them.
I look forward to your comments.
Post edited by Peter Fleming on
Or, has anybody heard of any modifications or tweeks being done to the RTi10's?
They are a good HT speaker, but IMO they struggle as a music speaker. -
As far as music i think they suck. I sold my RTi8s to get the 10s
and wish i still had the 8s.
jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
Basement-Audiosource pre/tuner,GFA-545,Onkyo
DX-1400 and RTI10s
Garage-GTP-450,onkyo M-282 and R50s with RTi55
drivers and X-overs.
My baby 18' V-king Mod VP with a merc 2.4 BP.
KTM 620 Supermoto -
I agree, I was attempting to be diplomatic! I virtually gave away my 10b monitors for the RTi10's. Can you feel my pain?hydrostream wrote: »As far as music i think they suck. I sold my RTi8s to get the 10s
jerry -
Peter, try putting a 1ohm resistor in line with the positive feed to the tweeter(s). This should tame down the top end. The RTi-10's are an excellent speaker. They were just built and designed for HT and not 2-channel. With that in mind, when you tame the tweeter it should become a great speaker for 2-channel.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I say find a speaker you do like instead of putting money and time into a speaker you hate. After doing tweaks & mods it's still going to be a RTI 10.
True Lee, but for a mod that is of a $3.00 value? Come on man. It's worth a shot. Who knows? It may become the speaker that rocks his world.
For no cost, the OP could always change it back for free.
Hi treitz3, I had heard of that before, and considered doing it, however the biggest flaw with these speakers is the constrained, underwhelming mid-range and limited soundstaging. My RTi10's are well and truly "burned in" and I had hoped they would open up with time. I've change amp's and borrowed several others with the same result.
They are beautifully constructed and a well finished speaker. It is very disappointing that these were made by Polk. I had my Monitor 10b's for 25 years and loved them, and assumed the RTi10's would be the next level. It's only recently I learned they are a HT speaker. I would describe them as a 2-way speaker - plenty of bass and tons of treble, but nothing in the middle!Peter, try putting a 1ohm resistor in line with the positive feed to the tweeter(s). This should tame down the top end. The RTi-10's are an excellent speaker. They were just built and designed for HT and not 2-channel. With that in mind, when you tame the tweeter it should become a great speaker for 2-channel. -
That one mid driver is the killer for the rti 10's
Hi leroyjr, I had the same thoughts about wasting money on something that may never deliver. I just wondered if others had come up with a solution, or dare I say, a RTi10 upgrade kit for 2-channel music!
I listened to a set of entry level B & W 684's the other day with an average, low wattage amp and they just rocked!! Brilliant soundstage and midrange. Since then I haven't listened to my RTi10's.I say find a speaker you do like instead of putting money and time into a speaker you hate. After doing tweaks & mods it's still going to be a RTI 10. -
Peter Fleming wrote: »Hi leroyjr, I had the same thoughts about wasting money on something that may never deliver. I just wondered if others had come up with a solution, or dare I say, a RTi10 upgrade kit for 2-channel music!
It's sometimes hard to build a all in one system that satisfies both home theater & music needs. Thats why so many people build a seperate 2 channel rig.
My advice would be either find a speaker that performs well for both or build a seperate 2 channel system.
Look at the SDA line , many on here find them great for both. -
I was wondering if I replaced a bass driver with another mid driver. I have no technical knowledge on these matters, but I would assume this would upset the whole internal configuration, and I'd probably need a sub with my 2 channel rig? Its 2.0 channel for me, not 2.1.That one mid driver is the killer for the rti 10's
Peter Fleming wrote: »I was wondering if I replaced a bass driver with another mid driver. I have no technical knowledge on these matters, but I would assume this would upset the whole internal configuration, and I'd probably need a sub with my 2 channel rig? Its 2.0 channel for me, not 2.1.
That wouldn't work because the woofers are 7 inches and the mids are 6 1/2. Also you would have to redo you crossover. Too much of a hassel IMO.
Look at the LSI & SDA line of speakers.. May be a option for you. Why did you get rid of the monitors you had? -
You'd be right leroyjr, but HT speakers don't need to be as good or as expensive as speakers used for 2 channel stereo.
Unfortunately the RTi10's in Australia were expensive and traded on the Polk name. Had I known the RTi10's were an inadequate stereo speaker I would have retained my 10b's for the stereo rig and purchased some cheaper bookshelf speakers for the HT. I would be a $1000.00 in front had I done that!It's sometimes hard to build a all in one system that satisfies both home theater & music needs. Thats why so many people build a seperate 2 channel rig.
Just realized your in Australia. Do you have any stereo shops near you?
I got rid of the 10b's because I fell under the spell of HT. When I got bored with it and returned to music, I realised I stuffed up. Yepp, I'm a dickhead, I have no defence!That wouldn't work because the woofers are 7 inches and the mids are 6 1/2. Also you would have to redo you crossover. Too much of a hassel IMO.
Yepp we have a few here, and was hoping to exhaust all avenues before losing tons on the RTi10's and spending more on new speakers. I'm not sure if it's pride, or facing my tone deaf wife?Just realized your in Australia. Do you have any stereo shops near you?
When I bought my RTiA7's I had first demo'd the Rti10's which are basically the same speakers in a new housing. But something was different. The A7's weren't nearly as bright and in my opinion had a more pleasing midrange. I have to assume that there was a crossover change of some kind from the 10's to the A7's that made the A7's a much better sounding speaker for music.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I'm running a Accuphase E205 amp, Rega 3 TT with Ortofon Rhondo Blue MC, Rotel 820B CDP, Esoteric Audio Speedcable, and Ugly interconnects.anonymouse wrote: »What does the rest of your rig look like? Source, processing, interconnects, amp, speaker cables?
Have you checked out ebay or craigslist for any Polk speakers in your area or willing to ship?
Do the crossovers. Get some decent caps, and you mids will clear up for sure. I never really cared for the too laid back sound of the mids in the LSI's, but some new caps, and resistors and it was better than all good.
Ben -
Hi Leroyjr, no mate, my love of Polk speakers (new) is over. If a set of older Polks came my way like SDA'a or monitors then I'd jump at them. With new speakers I'd go B&W, Dynaudio, Quad, Focal ........Have you checked out ebay or craigslist for any Polk speakers in your area or willing to ship?
Hi ben, I think that would be an unjustified costly exercise as I wouldn't be able to do the task myself. I think in the end they would still lack the integrity of a decent music speaker. If I could hear some that had been tweeked and I would know the end result, well that could be a different scenario. But in this instance I'm not going to take the gamble.Do the crossovers. Get some decent caps, and you mids will clear up for sure. I never really cared for the too laid back sound of the mids in the LSI's, but some new caps, and resistors and it was better than all good.
Ben -
Well I bit the bullet and took the loss ($). I sold my RTi10's as I could not listen to them any longer.
I'm now considering purchasing B&W683's. I had a demo with my R3 TT and Accuphase amp, huge stepup from the Polks.
Also considering the Dynaudio Audience 72's. Both speakers are currently well priced due to the current economic climate! -
I have RTi10's and 10B's
the 10B's truly do blow away the RTi for music -
Hi wizzy, well it's good to know it wasn't all in my head! If only I'd done a direct comparison with them I would be in possession of the 10b's and $1100.00 richer! A lesson well learned.
Moving on though, I ordered a set of B&W 683's today and hope to get 'em soon! Hopefully my love for music will be an enjoyable pastime again??I have RTi10's and 10B's
great, i'm in the same boat with my disappointment in the rti10's looks like another pair for sale soonSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Hi sandworms, I feel your pain. I went through denial, then disappointment, then disgust, then sold them! My new B&W683's have reminded me why I like music!great, i'm in the same boat with my disappointment in the rti10's looks like another pair for sale soon
Peter, Today was the first time I really sat down and listened to my monitor 10's for a couple hours. All I can say is they do IMO sound better than my RTI's and LSI speakers for music. I was very impressed and the thing about it is they can be had in the U.S. for about $100. Best $100 speaker I've heard so far.
I'm starting to sound like the old timers on here. :eek: -
Geez, you know how to hurt a guy! Honestly though you don't know how fortunate you are living in the US when it comes to hi-fi. I look at a lot of used hi-fi sites and FS forums in the US and the stuff that is available is mindblowing, and the price brings a tear to my eye! Yes it is true, I suffer from vintage hi-fi envy! Good condition monitor 10's would go for about $450 to $600 AUD, and our dollar has copped a smashing recently! But you are right, they are the best sounding speakers for a $100, it's gold Jerry! I was contemplating coming over there when the Aussie dollar picked up and fill a sea container of quality bargain hi-fi gear and bring it back here and open shop. Perth is the most isolated capital city in the world, but when it comes to hi-end vintage hi-fi it's almost like living on Gilligan's Island! As for old timers and vintage hi-fi - bring it on! Enjoy those 10's, for me.Peter, Today was the first time I really sat down and listened to my monitor 10's for a couple hours. All I can say is they do IMO sound better than my RTI's and LSI speakers for music. I was very impressed and the thing about it is they can be had in the U.S. for about $100. Best $100 speaker I've heard so far.
