blue ray dvd and sanyo plz4 720p
moraks
will a blue ray dvd player work with the sanyo projector and if it does will it make a significanf diffrence, i currently have the oppo 971h
Post edited by moraks on
Yes it'll work but your only going to get 720p/1080i not 1080p
Make sure to use the HDMI cable- a Radio Shack brand is fine.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
He might not have a hdmi input in back. -
i do have hdmi cable in the back of the projector, so will it have a signicant improvement in the picture and what will happen when i try to play my old dvd collection in the blue ray player?
Your old DVD's will look better if your BR player upconverts SD dvd's like most do. With the HDMI you should notice a better picture and in many cases better sound.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
