Take it off, girls!!!
Early B.
Early B. Posts: 7,900
edited September 2009 in 2 Channel Audio
I was foolin' around with my speakers yesterday and decided to experience them naked. Of course, I've heard for years that a cheap tweak is to take off the grilles, but didn't pay it any attention. I noticed that with the grilles on, they speakers sounded a bit muffled, whereas when the grilles were off, the sound was "unveiled."
Try it. You might like it. My grilles weigh several pounds each due to lots of 3/4" MDF, so the effect might be more significant. I can now understand why some designers recommend removing the grilles, while others expect the listener to keep them on. The grille probably has to be factored into the design.
"God grooves with tubes."
Post edited by Early B. on
«13
  • janmike
    janmike Posts: 6,146
    edited November 2008
    ALL my speakers are naked. Always have been and always will be. Just love the look.
    Michael ;)
    NORTH of 60°
  • McLoki
    McLoki Posts: 5,231
    The grills never come off my speakers. I don't even want my kids to know there are things that move under those grills.....
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    I left mine off for the Lsi's but for my Haydn's manual says not to clean dust off the tweeter since it may damage the tweeter. I figure if that sensitive better leave them on.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • george daniel
    george daniel Posts: 12,096
    mine are neked
  • ben62670
    ben62670 Posts: 15,969
    I don't even have no stinken grills!
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    Mine are always covered. One less thing that I need to dust!
  • ben62670
    cfrizz wrote: »
    I don't have to dust. Everything here is already covered:D
    Ben
  • Systems
    Systems Posts: 14,872
    Early B. wrote: »
    Yes some designers (ie Paradign , PSB) have the effect of the grilles taken into consideration when voicing them,others recommend removing them.
    None of mine have grilles.
    Testing
    Testing
    Testing
  • del44
    del44 Posts: 686
    The woofers are grilled but not the mid or tweeter. The speakers don't even come with grills for the top end.
  • Early B.
    I put the grills back on. My naked speakers were **** with my mind. With grilles off, my speakers look like some serious muscular party speakers due to their dual 12" woofers. Not cool with jazz vocals. Can you imagine Arnold Schwarzenegger singing soprano?
  • Igo
    Igo Posts: 411
    McLoki wrote: »
    That's hilarious.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
  • SolidSqual
    SolidSqual Posts: 5,218
    Early B. wrote: »
    Rookie
  • Igo
    Igo Posts: 411
    I'm surrounded by nakid ones. Both woofers AND the tweeter showin'. Blushing as I type in fact. Man, I gotta go close my curtains.
  • megasat16
    megasat16 Posts: 3,521
    LSi speakers and all Polk speakers are recommended with grilles On, I think. It's too diffract the sound waves but it seems no difference the grilles on or off for my LSis. I have mine with grilles on because I don't want my fur friend to ruin the driver (and liners).
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • BottomFeeder
    BottomFeeder Posts: 1,684
    Clothed when others are present, nekid when they aint.
    I take them off when I'm seriously listening...
    "Wish I didn't know now what I didn't know then." Bob Seger
  • shadowofnight
    shadowofnight Posts: 2,735
    cfrizz wrote: »
    Mine still get dusty with the grills on...all those woofers pumping back and forth move a lot of air. The larger particle more abrasive dust stays outside the grill, and inside the grill its that super fine dust.
    The ones that really get dusty even when the grills are on are the time aligned slanted variety like my LV Sat's
    I leave the grills on in the HT and off when listening to music in the mancave :D
    The first rule of Fight Club is you don't talk about Fight Club
  • Early B.
    Shadow -- what kind of speaker is that?
  • Systems
    Early B. wrote: »
    Audio Concepts Inc.LV and Titans?
    Testing
    Testing
    Testing
  • mmadden28
    mmadden28 Posts: 4,283
    I'd imagine that if you play a steady sine and have somebody place and remove the grill for you (at least hold it in front (A/B) you might be able to better tell if it makes a difference, right? Or jave them wave it in front, then you might hear a warble of sorts.
    When somebody walks in front of me when I'm listening the pitch changes or the sound changes. Yesterday when I was messing with REW and playing a steady sine, my son opened a door to an adjacent room (about 20' away from the speakers and behind me) and I immediately noticed a change in the pitch or something of the sine when the door opened and closed. I thouhht to myself-now that was interesting. It was immediate and evident.
    For me, I keep the grills on-mainy for same reason as McLoki. But I love to see the excursions on the sub--I let the grills breathe once in awhile. Last time I took the grills off, I forgot to put them back on--My boys found them and decided to have some fun and one of them was broken in two places :eek::eek: :mad: I think they were trying to use it as a ramp to climb onto the couch. You can't knotice it when its on, but --well at least they KNOW not to touch the drivers.
    ____________________
    Pool: Atrium 60's/45's
  • shadowofnight
    Early B. wrote: »
    GV#27 wrote: »
    Yup...Audio Concepts...subs long gone but I still had 2 pairs of the LV sat's and just gave one pair away to my buddy that got my second pair of SRS's.
    F1nut Posts: 51,951
    Grills on, always.
  • TroyD
    TroyD Posts: 13,124
    Me too...
    BDT
  • Braddles
    Braddles Posts: 228
    Kids up = grill on.
    Kids in bed = grills off.
    Amp - Jas Audio Bravo 3.2 set
    Power Cord - Tunami GPX
    CDP - Marantz cd6002 - Audio gd Ref 5 Dac
    Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Grills always on mostly because of my 4 year old. When I had ported speakers I found Polly Pocket stuff stuffed in the port. And when she is watching TV laying on the floor she likes to build forts and put her feet on stuff like drivers. When the grill are on my speakers are invisible and when the grills are off they are something to mess with.
    On 1 specific album "Wilco Sky Blue Sky" I listen with the grills off because the HF is so laid back on both my CD and 180G vinyl that taking the grills off helps a bit.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Grills always on. No reason to have them off and they were designed to be in place when in use.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    transpondent is the word of the day.
    RT1
  • Hawkeye
    Hawkeye Posts: 1,313
    Can't remove the grills from my speakers. If I did, I'd have no speakers!
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Ricardo
    Ricardo Posts: 10,634
    Early B. wrote: »
    I noticed that with the grilles on, the speakers sounded a bit muffled
    Are these the speakers you say you'll never change? Have you listened to muffled sound all these years? You should get out and see what's out there more often......:rolleyes: :D
    SOPA
  • dee1949
    dee1949 Posts: 1,425
    ...did you ever see the Meadowlark Kestrel design? The grille consist of just grille clothe that stretches over drivers and slips into a channel on the sides of the drivers mounting board....Wonder why more speakers aren't designed this way? No hard surfaces extending in front of drivers.
  • Ricardo
    Oh, and I keep mine always on, with the exception of the Danes; they look too beautiful to cover them.
    SOPA
