Shotguning cables
chargerman426
I'm not sure if I understand this concept. Is "shotguning" were you take to speaker wires and twist them together to make a bigger gage wire? Please help and whether or not its worth doing.
If life had more tubes it would be a lot smoother.
Post edited by chargerman426 on
Shotgunning is running 2 lenghts of speaker wire to the same speaker. It can be used to bi-wire or to lower the overall gauge by 3ga. (i.e. a shotgun run of 12ga. speaker wire will effetively end up as 12ga if used for bi-wiring or 9ga if used as standard cable.)
Talking about gauge... What gauge should I use for my speackers? RTi10's, CSiA6; receiver is Pioneer Elite VSX-92. The speakers are about 6-7ft. from the receiver.
ThanksHT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
at those short runs anything from 18ga up will do
Michael
McLoki, can you expand on your answer?
I had my Polk RTi8s bi-amped so I know what that is.
I had not heard of shotgunning until recently. Is it the same as bi-wiring ?
Thanks,Speakers: SDA-1C (most all the goodies)
It's pretty much the same thing as bi-wiring for speakers that are made to be bi-wireable (2 speaker inputs - 1 for the highs and 1 for the lows). If you only have 1 speaker input, then you would be upping the overall gauge going to the speaker.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
But is it a noticeable upgrade? I mean i don't believe in the cables make a difference but I think big gauge is something that matters.If life had more tubes it would be a lot smoother.
A nice 16 or 14 gauge wire will do perfect. Buy good quality wire.pablo_rodz wrote: »Talking about gauge... What gauge should I use for my speackers? RTi10's, CSiA6; receiver is Pioneer Elite VSX-92. The speakers are about 6-7ft. from the receiver.
DanDan
You are talking about pretty short lenghts so I would imagine the cost will be pretty low as well.... 12ga or 14ga wire would be overkill for that length run but will fit your speaker fine so that is where I would start. Do you NEED it no - but the cost difference will probably be under $10 so why not?
Then again - thats just me, I like to overbuild things....
chargerman426 wrote: »But is it a noticeable upgrade? I mean i don't believe in the cables make a difference but I think big gauge is something that matters.
Is it noticable to someone who does not believe cables make a difference and probably believes their wire is already of sufficient guage? - No. Shotgunning will increase the ga. by 3. So a shotgun of 18ga wire will be the same as if you purchased 15ga. to start with. (assuming you are not bi-wiring)
Pre - Nak CA-5
BR - LG BD390
Ok, please help me understand this...
I have bi-wireable speakers (Aerial Acoustic Model 6) and I know I need to get some good cabling & intend to, but funds are short right now. So how, exactly, would I bi-wire my speakers by using regular speaker wire?
Would I wrap two strands around each amp binding post and then separate them at the speaker terminals? Is there a precise way of doing this? I'm afraid that I might screw something up!
Thanks for your help. Please spell it out cuz I gots me no clue!"Wish I didn't know now what I didn't know then." Bob Seger -
If you're hung up about what gauge this, what gauge that, you've missed the boat.Political Correctness'.........defined
President of Club Polk -
Short and sweet......I dig it.:)HT SYSTEM-
lsi 9's -
I understand what your saying regarding gauge but I have to wonder why your cables are the size of garden hoses.
Drew -
If you're hung up about what gauge this, what gauge that, you've missed the boat.I understand what your saying regarding gauge but I have to wonder why your cables are the size of garden hoses.
Drew
He's compensating for something. (go ahead and ask him why the ends are so shiney.....)
BottomFeeder wrote: »Ok, please help me understand this...
Yep, that's it. -
OK here we go
Nut why are your ends soooooo shiney? -
To make this easy, get the Bluejeans Quad cable. Yes, you would pair the two up on the amp/AVR side.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
If i had know this was going to be about who's hose is bigger i would have bought 1 gauge and shot gun that.
If life had more tubes it would be a lot smoother. -
VSchneider wrote: »at those short runs anything from 18ga up will do
Thanks for the response...
I have audioquest X2, it doesn't say the ga.:rolleyes:HT:
Living Room:
