Shotguning cables
chargerman426
chargerman426 Posts: 419
edited November 2008 in Speakers
I'm not sure if I understand this concept. Is "shotguning" were you take to speaker wires and twist them together to make a bigger gage wire? Please help and whether or not its worth doing.
If life had more tubes it would be a lot smoother.
Post edited by chargerman426 on
  • McLoki
    McLoki Posts: 5,231
    Shotgunning is running 2 lenghts of speaker wire to the same speaker. It can be used to bi-wire or to lower the overall gauge by 3ga. (i.e. a shotgun run of 12ga. speaker wire will effetively end up as 12ga if used for bi-wiring or 9ga if used as standard cable.)
    Michael
  • pablo_rodz
    pablo_rodz Posts: 331
    Talking about gauge... What gauge should I use for my speackers? RTi10's, CSiA6; receiver is Pioneer Elite VSX-92. The speakers are about 6-7ft. from the receiver.
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • VSchneider
    VSchneider Posts: 443
    at those short runs anything from 18ga up will do
  • thsmith
    thsmith Posts: 6,082
    McLoki wrote: »
    Michael
    McLoki, can you expand on your answer?
    I had my Polk RTi8s bi-amped so I know what that is.
    I had not heard of shotgunning until recently. Is it the same as bi-wiring ?
    Thanks,
  • curved
    curved Posts: 664
    It's pretty much the same thing as bi-wiring for speakers that are made to be bi-wireable (2 speaker inputs - 1 for the highs and 1 for the lows). If you only have 1 speaker input, then you would be upping the overall gauge going to the speaker.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • chargerman426
    But is it a noticeable upgrade? I mean i don't believe in the cables make a difference but I think big gauge is something that matters.
  • mantis
    mantis Posts: 17,318
    pablo_rodz wrote: »
    A nice 16 or 14 gauge wire will do perfect. Buy good quality wire.
    Dan
    Dan
  • McLoki
    McLoki Posts: 5,231
    pablo_rodz wrote: »
    You are talking about pretty short lenghts so I would imagine the cost will be pretty low as well.... 12ga or 14ga wire would be overkill for that length run but will fit your speaker fine so that is where I would start. Do you NEED it no - but the cost difference will probably be under $10 so why not?
    Then again - thats just me, I like to overbuild things....
    Michael
  • McLoki
    McLoki Posts: 5,231
    Is it noticable to someone who does not believe cables make a difference and probably believes their wire is already of sufficient guage? - No. Shotgunning will increase the ga. by 3. So a shotgun of 18ga wire will be the same as if you purchased 15ga. to start with. (assuming you are not bi-wiring)
    Michael
  • curved
    curved Posts: 664
    mantis wrote: »
    Dan
    Agreed.
    Pre - Nak CA-5
    BR - LG BD390
  • BottomFeeder
    BottomFeeder Posts: 1,684
    Ok, please help me understand this...
    I have bi-wireable speakers (Aerial Acoustic Model 6) and I know I need to get some good cabling & intend to, but funds are short right now. So how, exactly, would I bi-wire my speakers by using regular speaker wire?
    Would I wrap two strands around each amp binding post and then separate them at the speaker terminals? Is there a precise way of doing this? I'm afraid that I might screw something up!
    Thanks for your help. Please spell it out cuz I gots me no clue!
    "Wish I didn't know now what I didn't know then." Bob Seger
    F1nut Posts: 51,683
    If you're hung up about what gauge this, what gauge that, you've missed the boat.
    tonyb Posts: 33,066
    Short and sweet......I dig it.:)
  • NJPOLKER
    NJPOLKER Posts: 3,474
    I understand what your saying regarding gauge but I have to wonder why your cables are the size of garden hoses.
    Drew
  • McLoki
    McLoki Posts: 5,231
    NJPOLKER wrote: »
    Drew
    He's compensating for something. (go ahead and ask him why the ends are so shiney.....) :D
  • MLZ
    MLZ Posts: 214
    Yep, that's it.
  • NJPOLKER
    McLoki wrote: »
    OK here we go
    Nut why are your ends soooooo shiney?
  • curved
    curved Posts: 664
    To make this easy, get the Bluejeans Quad cable. Yes, you would pair the two up on the amp/AVR side.
    Pre - Nak CA-5
    BR - LG BD390
  • chargerman426
    If i had know this was going to be about who's hose is bigger i would have bought 1 gauge and shot gun that. :D;)
  • pablo_rodz
    VSchneider wrote: »
    Thanks for the response...
    I have audioquest X2, it doesn't say the ga.:rolleyes:
    HT:
    Living Room:
  • BottomFeeder
    MLZ wrote: »
    Yep, that's it.
    Thanks, MLZ!
    I'll try it!
