LSi9 or 15
mangata572
I think this has been debated before; however I dont remember the outcome. For 2- channel music should I go for the LSi15s or LSi9s and a good sub? This is for a 640 sq ft basement bar area with a 7 foot ceiling.
Post edited by mangata572 on
Listen to both, the networks are very different, the 15 is NOT *just* a 9 with an extra woof.
I don't know your tastes, what you listen to, how loud you listen to it, but in general, for 2ch listening I would say go with the 9's, and see if you even need to add a sub.
Cheers,
yeah, like what Russ said. For strictly 2ch I would go with LSi9. An *musical* sub is optional, albeit it won't hurt.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Thanks for the quick response Russ. I did not realize the 9s and 15s were different other than the cabinet / woofer. I wonder if the imaging is easier to set up with the 9s vs. 15s? The closest LSi dealer is about 2 hrs away, so I will probably get them from Crutchfield without listening to them first. I do like your suggestion of getting the 9s then adding a sub if need be. I am just going on the good responses from Club Polk. My music choice is just about everything from pop, classical, rock except for country and rap (however I do like some Kid Rock[is he rap/country?]). As far as how loud, well I guess that depends on how drunk we all are!
I guess you would say I like the 15's better, huh?
In fact, they are the most fragile speaker I've come across to date.
I have had my Lsi15's playing at 114db in 2 channel.They didn't crackel,they didn't pop,they didn't distort in any way and the drivers are still in tact........
Abuse is Abuse what are you going to do...............
My vote here is for the Lsi15's.I perer there sound over the 9's,which is almost exactly the same.......Dan
Sean,
How hard were you pushing the 9's? I run mine full range and pump them up really loud without a problem. I hope Polk took care of replacing the drivers for you. Did they charge you for the replacement?
Oh yeah, how's the SDA? Do you still like them more than the LSi?
As for the original question, I haven't heard the 15's but love my 9's and never felt the need to upgrade to the 15's.
Maurice -
I should get my 9's on monday or tuesday (Thanks Hoosier21 aka Russ), might have to set 'em up and see how they do compared to the 15's for 2 channel.
so Frank, what amp will you pair the 9 with?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Originally posted by polkatese
so Frank, what amp will you pair the 9 with? -
That would be a cool project, let us know how it mates...I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I am extremely hard on the LSi's I have at my disposal at work. Run on anything and everything for a receiver, and got the volume loud enough to shut several receivers down. No drivers have failed so far. We did lose the amp section in an LSi25 once (not sure what the problem was there). I would hardly term them a fragile speaker, let alone the most fragile. Check out some of the Sony HTIB's.
BTW, the Sum of All Fears seems to be a nasty film for speakers. I pretty much irradicated a PSW404 with the nuclear explosion scene. It was fun! Someone had cranked up the sub volume and I didn't realize it. Oops! -
Originally posted by ATCVenom
So again I ask - what the hell was the problem??
all due respect, your strangly strange about speakers.
seems your a hard one to please on speakers and equipment, keep searching maybe you will find the real deal someday??????MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Originally posted by Frank Z
For the time being I'm going to use my "old" Pioneer Elite M-10x (100x2 @4ohms) But I'm thinking about picking up a DIY tube amp kit. I'd like to get one that looks old to match my wifes antique Philco radio.
My experience with Lsi's and tubes was not a happy one. I tried a pair of 100W Manley mono blocks on my Lsi15's and was extremely disappointed. They could not drive the Lsi's reasonably. I think tubes are more of a voltage source and the Lsi's need more of a current source? In any case the Lsi's came alive when I hooked up a 350W per channel SS amp. Night and day difference here. (and I'm a tube guy).
ATC,
didn't mean to ruffle you all up but calling the Lsi's a fragile speaker simply isn't true.Your opnion I will respect it,but it just differs from my experience.....and thats fine man.
Speakers go bad,drivers go bad,sometimes they can be defective right from the get go,it happens.The fact that you bought your Lsi9's from online and no warranty I feel is a bad move.I know you saved some cash,but your speaker didn't get fixed under warranty.....Well that was the past and you have moved on since then so lets let that rest.
Abusive was a joke,You blew the hell out of your rt2000p's and seem to kill just about every electronic device you have owned recently,your string of bad luck if you will.....Dan
Madmax,
I'm kinda surprised to hear that. I've heard Lsi's driven by a Conrad Johnson tupe amp and the sounded incredible! -
Madmax,
The Manleys are great amps and the CJ's may be better... The very low volumes were nice but but it was like I couldn't get them out of second gear. (to use an old car phrase).
Max,
Thanks for the info. Between your comments and my discussion with Jerry yesterday, it's obvious that I'll have to do a lot of research before starting a DIY tube project. -
Just scanning this thread, but my $0.02:
Get the 15s - they extend to flat to ~ 33 Hz and would be perfect for a moderate volume 2 channel purist rig.
They could also perfectly serve double duty in a HT rig set to small with an 80 or 60 Hz crossver and a really good sub to deliver the huge deep impacts and air movement that HT demands.
The LSi9 would need a great sub and an 80 Hz crossover for both music and HT as it only extends flat to ~ 53 Hz - hardly adequate even for music.
Once you pay for a set of nice stands for the 9's, you come pretty close to the 15's anyway.
At one time I thought the 9's would be the WTG all around, but ATC's experience with them has me a bit wary and I think the 15's would be more durable over the long haul.
Doc"What we do in life echoes in eternity"
SVS -
Actually Doc......
I tested my Lsi15's and they played down to 32 flat......really impressive.They can play down in the 28hz range with about 6db loss.at 24hz they loose it and 22 there gone.No usable bass there.
The Lsi15's would best be paired with a REL Storm III.It's unique setup allows you to crossover the sub where you need it.It comes in around the 30 hz range for full range mains and also allows you to crossver again with it's dual preamps for HT at around 80 hz or so....where you need it.
The Lsi15's are the most impressive speaker in my opnion under 1700.00.The only pair that I have heard that would give them a close run for there money would be the Dynaudio Audience 72's.This is one shoot out I would personally love to conduct.
I would use some Rotel gear for the test.Dan
Hey mantis,
What do you think of the Kenwood higher end stuff for Lsi's? Any experience? I forget the name of the series. A friend seems interested in it.
Mad,
I have Installed tons of the Soviern Series.It's ok,I wouldn't mate it with Lsi.I feel the Kenwood doesn't yield the kind of sound quality to mate up with Lsi.
Here's what I believe in for Lsi in receivers.
1)B&K avr507
2)Rotel rsx1065
3)Rotel rsx1055
4)Pioneer Elite vsx49txi
5)Sunfire Ultimate receiverDan
Originally posted by mantis
Actually Doc......
Well there ya go, straight from the horses mouth. I figured flat to 33 and it's actually 32.
There is some music out there that goes lower than 30 Hz, and I agree for this the 15's would need a sub. For moderate volume you could actually crossover to the sub at 33-35 Hz.
However, many towers that are flat to 32 hz at moderate volume can't deliver the same 32 Hz at much high volumes without stress and distortion. This is known as a "non-linear" SPL/FR relationship.
At higher volumes typical of HT, you would need to crossover to the sub at a higher frequency because those woofs in the 15's hardly qualify as true rugged, high excursion woofs meant to deliver the massive impacts HT often requires. I'd use 60-80 Hz for HT with the 15's.
SVS -
Doc
Just wondering, what freq would you cross over the Lsi9's at?
madmax
The typical high pass filter rate is 12 dB/octave - that's a pretty shallow drop-off rate, hardly a brick wall.
Since the LSi9 is only flat to about 53-55 Hz, I would set the crossover frequency at 80 Hz for the LSi9.
That would still allow bass (albeit progressively diminishing in amplitude) to be sent to the LSi9's well down into the 50 Hz region.
SVS -
80 is where I have my LSi 9's crossed over at usng a PSW 350 sub. Sounds great. I smell a sub upgrade coming in the next few months. I have to get the LSi center channel first though.
Paul -
Paul,
Did you try bi-wiring the 9's straight from the amp? I actually lived with the 9's with a single wire run for a few days and it didn't sound as good. I was able to tell the difference(same with the 800i's). Did the sound quality stay the same after passing through the filter in your PSW350? I was thinking about using the filter in my PSW650 but I'm not sure if the filter is of good enough quality. I'm currently running them full range and love the sound. It should be fun to try filtering them. I'll try it when I have time.
Maurice -
Frank,
Do you plan on integrating the 9's with your present system ?
Or plan on putting together another system ?
I'm thinking on going with 9's and a 2-channel stereo setup only.Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111 -
Not too sure yet. I think I'll set them up in my living room and connect them via the Pioneer receiver for the time being. I've also got a Yamaha receiver in my bedroom that I may use with my 2 channel amp.
Decisions, decisions!:D -
They will handle that duty FINE. The LSi9 is (imo) the flagship of the line, and, when properly driven, can handle 2ch like a charm, no sub needed. I'm not going to get into a small-large-bass mgmt BS post, or debate 3db down ratings. We (as a general populous) have been running 2ch rigs full-range since the inception of 'stereo' with NO issues, as long as the 'assumed' rules are obeyed (clipping etc).
This you can quote me on:
The LSi9 is a phenomenal 2ch stereo speaker, when properly driven. Incredibly flat, and very detailed. Mid range is second to none, vocals come through (both male and female) with clarity and balance, and the bass is outright retarded for a speaker this size.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Maurice,Did you try bi-wiring the 9's straight from the amp? I actually lived with the 9's with a single wire run for a few days and it didn't sound as good. I was able to tell the difference(same with the 800i's). Did the sound quality stay the same after passing through the filter in your PSW350? I was thinking about using the filter in my PSW650 but I'm not sure if the filter is of good enough quality. I'm currently running them full range and love the sound. It should be fun to try filtering them. I'll try it when I have time.
The beauty of the PT5 preamp and why I fell in love with it is that besides being a B&K product, it has a sub output on the back of the preamp. The sub is filtered at 80 hz with a 12 db per octave slope. In addition it has preouts for full range for the mains and for high pass at 80 db for the mains. I use the 80 hz high pass with the sub so do not filter at the sub. this is essentially the same as running a receiver with the mains set to small and a sub. This is a great feature for a preamp in this price range that I didn't see with Adcom or NAD; hence my decision to purchase the B&K. I did try full range on the LSi 9's with the sub output on the preamp going to the sub but I found it a little "boomy" for my taste. Also generates standing waves and that's a whole different discussion with cancellation. Furthermore, I found the midrange to clear up a bit with the LSi 9 crossed over at 80 and letting the sub take care of the lows. This helps to free up power for the main amp to handle the mids / highs. Also extra insurance that I won't be sending low stuff to the nines which they may be sensitive too since some members feel that the nines are easy to bust (I haven't had any problems with this; never even heard the woof bottom out yet).
Paul
P.s. Yes .. biwire is the way to go..
