New System....Help!
steve0202
steve0202 Posts: 28
I bought a Sony HT5500D 5.1 Home Theater system 6 months ago. (5x100W DTS receiver). Did not enjoy the sound so I have in transit to me the following: Pair of RTi70's, PSW-250,CSi30, and 2 RM series II satellites. Will the Sony receiver from the home theater system be OK for this speaker system? Would buying a Denon AVR make a noticeable difference? or do I need to go out and spend big money on a B&K AVR? I have a limited budget so I was hoping the Sony would be a sufficient receiver. Any thoughts would be appreciated.
Thanks,
Steve
Rti70's
Csi30
PSW-250
RM5000 series II sats
Denon AV2802
Denon DVM 1815
Toshiba 32" TV/Monitor
Post edited by steve0202 on
  • mantis
    mantis Posts: 17,325
    edited May 2003
    You can use that receiver,it's a standard Sony AVR.
    I would save for a Denon avr3803 in the future.Thats what I believe you should use for that system you wanna build.
    The other receiver I would use would be the Pioneer Elite vsx45tx.
    Dan
  • organ
    organ Posts: 4,969
    edited May 2003
    Your Sony receiver will drive the Polks just fine. You should listen to the Polks being powered by the Sony first to see if you need a better receiver. A Denon will sound better. If you decide to upgrade the receiver, make sure you do a lot of research to find the one that's riht for you. There are plenty of good sounding receivers out there.
    Conrats on the new purchase. You're going to have a killer HT with the new speakers.
    Maurice
