Sub placement ideas!
pearsall001
My second Velo SPL-1200R is due to arrive this Friday. I'll be doing the hook up on Sat. Presently the 1st Velo is along the left side of my entertainment center about 12" behind my AAD monitor. I'm thinking that duplicating the same set up on the right side would be optimal.
I've also read about stacking two subs or placing them side by side...what are the advantages to this type of set up, if any. Having them flanking both sides of the entertainmemt center would be the best looking scenerio, but if the other options bring more to the table, I'm game. Suggestions!
Post edited by pearsall001 on
Well if you what to be "correct" the THX way then you put the sub up 1 in the front middle and 1 back middle. Here is a link to there page.
http://www.thx.com/home/setup/speakers/51.htmlIf life had more tubes it would be a lot smoother. -
From what I read on that diagram if you have 2 subs you are supposed to put them in the middle of oppsing walls, so if the front and back middle won't work you can also put them on the left and right under your surround left/right (if you have them) If you click on the subwoofer tab on the left of that page it explains it in the description.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Yeah they seem to only like the set up if you do it in pairs. The way I set mine up was by putting the sub in my normal listing position and then crawled around the room. You could just walk around it as well but that seems to be a good way to do it.If life had more tubes it would be a lot smoother.
Flank 'em like you planned.
Did it arrive today?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
One on either side of the listening field would do good let me know when you play iron man on that system. It should rock the house.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Phil, I don't know anything about subwoofers or their placement but I have the Black Sabbath "Paranoid" CD with Iron Man on it and it is one of the best sounding CDs I have. I started a thread on it a while back. I can bring it over.
If you get good bass response from a single sub through your listening area - stacking is where its at. This will give you the maximum benefit of additional slam and volume for your bass (to the tune of +6db - the equivilant of 4x the amp power). It will also give your current sub its best chance of not bottoming.
If the bass response in your room is not that great (you have lots of peaks or nulls in your bass response) or you have a sweet spot that barely covers one seating area - spreading out the subs will work best for you. By each sub interacting with your room differently (for the best benefit - put the subs opposite each other in the room) you will get a much smoother response curve and your sweet spot will increase in size. The down side of this is that you only get a 3db gain (equiviant to double the amp power) but the better interaction with your room makes it all worth while.
Long story short - it depends on your room and its interaction with bass as to what sounds better (stacking or spread out).
Phil, have you made it clear that this is for your two channel rig?
hearingimpared wrote: »Phil, have you made it clear that this is for your two channel rig?
Did not realise that but the concepts will still be the same. As your crossover increases over 80hz though it becomes easier to localise where the bass is coming from. Based on that if crossing over at a higher crossover point, it may be worth while having the subs located near your mains (rather than spread out on opposite sides of the room).....Mains.............Polk LSi15 (Cherry)
Michael, aren't the low frequencies mono? I don't see the point in two subs for 2channel if indeed they are mono.
Depends on how loud you listen and how much you value headroom.
Also if you have a bad room for bass - you can get much better response curves if you have multiple subs spread out throughout the room rather than a single one.Mains.............Polk LSi15 (Cherry)
Thank you sir.
I keep breaking Phil's ballinis telling him that I don't need no stinking sub my 1.2 TLs ensure that.:D -
hearingimpared wrote: »Thank you sir.
Your 1.2 TL's will cower in the corner & weep tears in submission!!!
Delivery of the bad boy has been delayed to early next week. Dang!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Early next week. I was hopeing for this weekend. Oh well!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
I don't need no stinking sub!!!
hearingimpared wrote: »I don't need no stinking sub!!!
Hey, we're having a little fun again!! Let's keep it a secret so the wrong crowd doesn't chime in."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Well the fun guys are logged in tonight. Jesss is going to keep it so secret that you won't even see his posts!!!! WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
hearingimpared wrote: »Well the fun guys are logged in tonight. Jesss is going to keep it so secret that you won't even see his posts!!!! WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
Damn Joe! Don't you ever go to bed????? I should be picking the Velo up next week. When my system is put back together, it's time for a road trip!!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
subs suck!.....ssssssshhhhhhhh:DModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
pearsall001 wrote: »Damn Joe! Don't you ever go to bed????? I should be picking the Velo up next week. When my system is put back together, it's time for a road trip!!!
You are on Brother. -
Midnite Mick wrote: »subs suck!.....ssssssshhhhhhhh:D
Next time use spell check...didn't you mean to spell subs rock!!!
hearingimpared wrote: »You are on Brother.
Can't wait!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
