Sub placement ideas!
pearsall001
pearsall001 Posts: 5,341
My second Velo SPL-1200R is due to arrive this Friday. I'll be doing the hook up on Sat. Presently the 1st Velo is along the left side of my entertainment center about 12" behind my AAD monitor. I'm thinking that duplicating the same set up on the right side would be optimal.
I've also read about stacking two subs or placing them side by side...what are the advantages to this type of set up, if any. Having them flanking both sides of the entertainmemt center would be the best looking scenerio, but if the other options bring more to the table, I'm game. Suggestions! :)
Post edited by pearsall001 on
  • chargerman426
    chargerman426 Posts: 419
    edited November 2008
    Well if you what to be "correct" the THX way then you put the sub up 1 in the front middle and 1 back middle. Here is a link to there page.
    http://www.thx.com/home/setup/speakers/51.html
    If life had more tubes it would be a lot smoother.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    From what I read on that diagram if you have 2 subs you are supposed to put them in the middle of oppsing walls, so if the front and back middle won't work you can also put them on the left and right under your surround left/right (if you have them) If you click on the subwoofer tab on the left of that page it explains it in the description.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • chargerman426
    Yeah they seem to only like the set up if you do it in pairs. The way I set mine up was by putting the sub in my normal listing position and then crawled around the room. You could just walk around it as well but that seems to be a good way to do it.
  • Early B.
    Early B. Posts: 7,900
    Flank 'em like you planned.
    Did it arrive today?
    "God grooves with tubes."
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    One on either side of the listening field would do good let me know when you play iron man on that system. It should rock the house.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • hearingimpared
    hearingimpared Posts: 21,136
    Phil, I don't know anything about subwoofers or their placement but I have the Black Sabbath "Paranoid" CD with Iron Man on it and it is one of the best sounding CDs I have. I started a thread on it a while back. I can bring it over.
  • McLoki
    McLoki Posts: 5,231
    If you get good bass response from a single sub through your listening area - stacking is where its at. This will give you the maximum benefit of additional slam and volume for your bass (to the tune of +6db - the equivilant of 4x the amp power). It will also give your current sub its best chance of not bottoming.
    If the bass response in your room is not that great (you have lots of peaks or nulls in your bass response) or you have a sweet spot that barely covers one seating area - spreading out the subs will work best for you. By each sub interacting with your room differently (for the best benefit - put the subs opposite each other in the room) you will get a much smoother response curve and your sweet spot will increase in size. The down side of this is that you only get a 3db gain (equiviant to double the amp power) but the better interaction with your room makes it all worth while.
    Long story short - it depends on your room and its interaction with bass as to what sounds better (stacking or spread out).
    Michael
  • hearingimpared
    Phil, have you made it clear that this is for your two channel rig?
  • McLoki
    McLoki Posts: 5,231
    Did not realise that but the concepts will still be the same. As your crossover increases over 80hz though it becomes easier to localise where the bass is coming from. Based on that if crossing over at a higher crossover point, it may be worth while having the subs located near your mains (rather than spread out on opposite sides of the room).....
  • hearingimpared
    Michael, aren't the low frequencies mono? I don't see the point in two subs for 2channel if indeed they are mono.
  • McLoki
    McLoki Posts: 5,231
    Depends on how loud you listen and how much you value headroom.
    Also if you have a bad room for bass - you can get much better response curves if you have multiple subs spread out throughout the room rather than a single one.
  • hearingimpared
    Thank you sir.
    I keep breaking Phil's ballinis telling him that I don't need no stinking sub my 1.2 TLs ensure that.:D
  • pearsall001
    Thank you sir.
    Your 1.2 TL's will cower in the corner & weep tears in submission!!! :D
    Delivery of the bad boy has been delayed to early next week. Dang!!
  • pearsall001
    Early B. wrote: »
    Early next week. I was hopeing for this weekend. Oh well!!
  • hearingimpared
    I don't need no stinking sub!!!
  • pearsall001
    Hey, we're having a little fun again!! Let's keep it a secret so the wrong crowd doesn't chime in.
  • hearingimpared
    Well the fun guys are logged in tonight. Jesss is going to keep it so secret that you won't even see his posts!!!! WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • pearsall001
    Damn Joe! Don't you ever go to bed????? I should be picking the Velo up next week. When my system is put back together, it's time for a road trip!!!
  • Midnite Mick
    Midnite Mick Posts: 1,591
    subs suck!.....ssssssshhhhhhhh:D
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • hearingimpared
    You are on Brother.
  • pearsall001
    Next time use spell check...didn't you mean to spell subs rock!!! :D
  • pearsall001
    You are on Brother.
    Can't wait!!
