Change the jumper between the posts?
thajones
A friend of mine who uses Kimber like I said he found an audible difference by removing the brass(?) jumper from the rear posts on his B&W 604 S3 and replacing it with a short 1 1/2 inch run of Kimber. Has anyone else tried it? I did the same, but couldn't really tell the difference, or is it due to my "mid-fi" speakers?
The Kimber is 4pr, by the way.
Denon 1803 Receiver
Denon HDCD CD player and DVD Player
DTV HD Tivo Recorder
AR Pro Series Interconnects
Kimber Kable
48 inch Magnavision HD projection
Polk CS350 center channel
Polk RT10s
Polk RT/fx
AR 12" slot loaded sub
(Mirage Omnisat system almost complete)
Kimber Kable
Polk RT10s
Polk RT/fx
Post edited by thajones on
I have Kimber 4vs and noticed a difference when I removed the jumpers with my RT1000i.
I haven't tried a short run to replace the jumper though.
Do you notice a difference without a jumper at all?SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
You mean bi-wiring?Denon 1803 Receiver
Kimber Kable
Polk RT10s
Polk RT/fx
(Mirage Omnisat system almost complete) -
Yup.
Did you notice a difference between jumper and no jumper?SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
if you bi wire your speakers.. you need to remove the jumper.. no jumper.
if you do not bi wire your speakers.. yes replacing the metal jumper and replacing it with 12 guage wire is what several people recommend doing.
I can't say whether you'll hear an improvement or not. I tired the short wire run.. but couldn't hear any difference in my rt1000i and rt800i's.
AlPolkFest 2012, who's going>?
I actually have never tried bi-wiring, had a bit of difficulty convincing the Mrs that I just "had to have" those Macintosh monoblocks .
I suppose if nothing else I've eliminated one more point of failure in the quest for "perfect sound."
Interesting note though: Doing this made the banana plugs I used not seat completely in the binding posts, since I'm using bare wire. Overkill to even bother using spades for the wire jumpers?Denon 1803 Receiver
Kimber Kable
Polk RT10s
Polk RT/fx
If it adds to your musical enjoyment and the convenience of the use of your system, it is not overkill.
I, like others, have always heard an improvement when replacing the flat metal binding post straps with heavy gauge speaker wire.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Duh, I got the quote, but not my $.02
Bi-wiring doesn't need any additional amps. It is just running 2 sets of wires from one amp. I too have replaced the jumpers on a set of speakers. It works and is easy to do.
Bi-amping needs separate/additional amps, but that's a whole different story.Make it Funky! -
Originally posted by gidrah
all the more reason to biamp:rolleyes:***WAREMTAE*** -
Mac mono-blocks..... need pictures... need pictures....More later,
Tour...
Vox Copuli
Yeah, I'm slow. I just read an article yesterday that explained the whole bi-amp/bi-wire thing.
The bi-amping thing does not increase the load to the amp? I would think running in parallel would change the load, making it less efficient (higher ohms)?Denon 1803 Receiver
Kimber Kable
Polk RT10s
Polk RT/fx
Good question, tj I never stopped to think about the load impact of bi-amping, but yes, you are eliminating the parallel operation of drivers so the impedance seen would rise. However, I would not assume that increasing impedance would reduce speaker sensitivity.
The gain is reduced frequency duty for the amps great deal for the mid/ hi freq amp, not so much for the amp driving the woofer(s). Still in bi-amping, assuming identical amps all the way around, you are doubling the power available.
Anyway there is a third option some employ, bridging amps to mono, with or without bi-wiring. But that kind of brings us full circle in your caseMore later,
Tour...
Vox Copuli
