Current future amp help
StevenFo2
Hello guys,
I currently have an avr-645 and get little bass from my rti10, I have considered buying an rotel rmb-1085 which is 100 watts per channel vs my 75watts. If I were to biamp the speakers with the 1085 would I see any improvement? Second question is for down the road would the 1085 work well with a 5 channel lsi setup(lsi25 mains)?
Can you explain what this means
4 ohm load, 1kHz, <1% THD: 180 watts
Would these specs give me good audio with lsi?
Thanks for the help
Thanks for the help
Post edited by StevenFo2 on
I currently have 16 guage monster cable.
As for the 1085 being measured at 4 ohm load, 1kHz, <1% THD: 180 watts, I noticed the newer models were mesured 200 watts x 5/ch (20-20 kHz, 0.03% THD, 4 ohms. Would this difference be worth waiting for the newer model rmb-1565?
Thanks for your help -
You should get some 12guage or at least 14 guage speaker cables like audioquest or DH labs T-14 cables.I use the T-14 hooked up in a shotgun configuration and love it.(that makes it 11 guage)Monster is overatedSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
If you are planning on stepping up to the LSI's then YES wait for the RMB-1565 to come out & get that. It will make a big difference with the speakers you have now as well.
As for speaker wire take a look at Monoprice, BlueJeans Cable, and Signal cable for better wire.
Welcome to Club Polk.:)I currently have 16 guage monster cable.
Thanks for your helpMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
