MiDock
Alteration
MiDock 10
Does anyone know how to disassemble the MiDock 10 for iPod? I have already mod'd it to work with iPhone (docked) but want to make another mod. Thanks for any input.
PS. with the iPhone docked it looks sick!!
Post edited by Alteration on
2 screws in the battery compartment, 4 screws under the rubber feet. If you need to ask then maybe you shouldn't be in there IMHO
But above all....
Welcome to Polk Audio forums.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I've looked under the rubber feet and didn't see any screws. I had found the two in the battery compartment and one in the front behind the dock door. Could you be thinking of another dock?
Alteration wrote: »PS. with the iPhone docked it looks sick!!
Well let's see! -
Alteration wrote: »I've looked under the rubber feet and didn't see any screws. I had found the two in the battery compartment and one in the front behind the dock door. Could you be thinking of another dock?
I'm thinking of this product.
http://www.polkaudio.com/homeaudio/products/ipod/products/midockportfolio/
Is this what you have, if so there should be screws under the rubber feet.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I eventually figured it out (each side). On the side panels behind the handles a plastic layer is glued on and conceals 6 screws. Also the speaker grills must be removed from the front and three screws are in each. This will allow you to release the front of the box. After inspecting the interior design I decided not to install the slide-out 7" LCD.
Adapting the dock door to accept the iPhone turned out well. As a little body modification is neccesary, I found a dremel with a few different tips worked well.
*note: the phone will not charge unless connected via sync cable and USB power block.
I will post pics when I get a chance -
The MiDock 10 was a Radioshack exclusive.
I've been working from my iPhone for the last couple days and am not able upload the pics until it get to my desktop -
Alteration wrote: »*note: the phone will not charge unless connected via sync cable and USB power block.
Which is fair with me as 4 AA batteries would drain very fast if Ipod was dead needing a charge. But I should this could be mod if needed in the AC/DC power jack.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Alteration wrote: »The MiDock 10 was a Radioshack exclusive.
Ok so you really confused me at first. First post on Polk Forum then state MiDock LOL
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Pics of my modified MiDock 10 for iPhone
