MiDock
Alteration
Alteration Posts: 7
edited November 2008 in DIY, Mods & Tweaks
MiDock 10
Does anyone know how to disassemble the MiDock 10 for iPod? I have already mod'd it to work with iPhone (docked) but want to make another mod. Thanks for any input.
PS. with the iPhone docked it looks sick!!
Post edited by Alteration on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2008
    2 screws in the battery compartment, 4 screws under the rubber feet. If you need to ask then maybe you shouldn't be in there IMHO
    But above all....
    Welcome to Polk Audio forums.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Alteration
    Alteration Posts: 7
    edited October 2008
    I've looked under the rubber feet and didn't see any screws. I had found the two in the battery compartment and one in the front behind the dock door. Could you be thinking of another dock?
  • zingo
    zingo Posts: 11,258
    edited October 2008
    Alteration wrote: »
    Well let's see!
  • disneyjoe7
    edited October 2008
    Alteration wrote: »
    I'm thinking of this product.
    http://www.polkaudio.com/homeaudio/products/ipod/products/midockportfolio/
    Is this what you have, if so there should be screws under the rubber feet.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Alteration
    Alteration Posts: 7
    edited October 2008
    I eventually figured it out (each side). On the side panels behind the handles a plastic layer is glued on and conceals 6 screws. Also the speaker grills must be removed from the front and three screws are in each. This will allow you to release the front of the box. After inspecting the interior design I decided not to install the slide-out 7" LCD.
    Adapting the dock door to accept the iPhone turned out well. As a little body modification is neccesary, I found a dremel with a few different tips worked well.
    *note: the phone will not charge unless connected via sync cable and USB power block.
    I will post pics when I get a chance
  • Alteration
    Alteration Posts: 7
    edited October 2008
    The MiDock 10 was a Radioshack exclusive.
    I've been working from my iPhone for the last couple days and am not able upload the pics until it get to my desktop
  • disneyjoe7
    edited October 2008
    Alteration wrote: »
    Which is fair with me as 4 AA batteries would drain very fast if Ipod was dead needing a charge. But I should this could be mod if needed in the AC/DC power jack.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited October 2008
    Alteration wrote: »
    Ok so you really confused me at first. First post on Polk Forum then state MiDock LOL :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Alteration
    Alteration Posts: 7
    Pics of my modified MiDock 10 for iPhone
