Wrinkles on my screen
dholmes
dholmes Posts: 1,136
edited October 2008 in DIY, Mods & Tweaks
What is the best way to get rid of wrinkles on my pull down dalite screen,I have it wall mounted.The wrinkles are horizonal,is there a way to streech it? I tried heat & that didnt work,thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • scootchu
    scootchu Posts: 100
    edited October 2008
    FWIW- That was the thing that I read that kept me away from either motorized or manual pulldowns and went with a fixed screen.
    My first thought was even weight across the bottom somehow and letting it sit, but someone probably has a better way.
  • dholmes
    edited October 2008
    Thanks, how does a fix screen work to keep wrinkles away?
  • dholmes
    edited October 2008
    Anyone with the wrinkles!
  • scootchu
    scootchu Posts: 100
    edited October 2008
    dholmes wrote: »
    Fixed, meaning always there mounted to the wall. I had heard that the material in the retractibles developed wrinkles when rolled up for lengths of time. Common sense logic would dictate that letting the material hang over time, maybe with some even weight would pull them out.
  • dholmes
    edited October 2008
    I originally got the pull down screen so I could roll it up & watch tv,but got rid of the tv & mounted the screen on the wall & thats been 4 yrs ago,I thought someone knew of a trick to get rid of them,the wrinkles are vertical top to bottom. Its a good screen from Dalite thick materal.thanks
  • Tollaksen
    Tollaksen Posts: 71
    edited October 2008
    How is it mounted to the Frame?
    Is the frame reinforced in the middle?
    Are the wrinkles deep creases or just loose fabric?
    The reason that I ask is that a steamer works wonders for certain types of wrinkles. But if it is sagging then there is different tricks. I have built a few screens and had a handful of problems along the way.
    Reciver Pre/Pro - H/K AVR-347
    Amplifier - Adcom-7400 5 Channel
    Speakers - SRT's
    Projector - Sony Avl-aw15
  • dholmes
    edited October 2008
    Thanks its not a wrinkle but a dip in the sreen,I check to make sure that its level.The screen is a Dalite c model that has something in it to make it easier to roll up which I dont do anymore.The screen is a thick material.
  • Jeff Beaird
    Jeff Beaird Posts: 217
    edited October 2008
    When you or the installer installed the screen, Is it mounted to the wall hanging by the outside corners? And not supported in the middle?
    What I am trying to get at, is middle sagging at all? Even 1/4" across a 5 or 6 foot area will produce wrinkles. If you have a 4 foot level, if not borrow your nieghbors, and put that across the top of the screen housing. See if there is a gap between the level and the housing.
    I'm guessing a roll-up screen is not designed to be unrolled for an indefinite amount of time. The weight of the unrolled screen over time would allow the roller to sag slightly.
    If you plan on leaving it down, mount it to a quality piece of MDF, plywood, or melamine. Problem solved...:cool:
    Thanks, Jeff...
  • dholmes
    edited October 2008
    Thanks Jeff I found out that it was the wall behind the screen.
