tweeters
Airplay355
Airplay355 Posts: 4,298
edited May 2003 in Speakers
i have rti100's and a cs245i, i wanted to know if it would be necessary to upgrade the center channel to the cs400 so the tweeters would all be the same. how come the csi40 doesn't have the same tweeter as the rti100s? (tri lam dome i think) are there advantages to sticking with the regular tri lams? sorry if im confusing you guys but im a bit confused myself, basically i wanna know if there is any difference between the two tweeters and if it would sound better to have the same tweeter throughout my front sound stage
Post edited by Airplay355 on
  • faster100
    faster100 Posts: 6,124
    edited May 2003
    The 100's have the same tweeter, they are part of the new line up.. as the csi40.. the 400 wouldn't match.. you wouldn't tell much difference but on the front stage you really want it matched speaker wise, power and wire some say.. i say get the 40, it matches, the cs400 is no longer available unless you find one used.. I bought my csi40 used for like 230-240 can't remember.. It was like couple weeks old said the seller.. I love it, so massive so long as you have a TV to fit it.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    VR3 Posts: 28,134
    edited May 2003
    the Silk dome is MUCH MUCH smoother than the Tri-Lam. IMO ALL DA WAY THOUGH!
