floorstanders - why necessary?
blakflag
blakflag Posts: 3
edited October 2008 in Speakers
Hi all,
For a while now I've been trying to figure out how to step up the audio quality of my setup. I have a Polk RM6700 system with PSW404. The 404 is enough bass for me but I am ready for some more definition in the mids and highs. (I use nice audio monitors for computer speakers so I'm starting to get snobby)
My room is currently 13x13x8 with an open floorplan.
I see that most people here like floorstanding speakers, but I really don't quite grasp the necessity. Isn't that what the sub/satellite combination was meant to solve? I kind of like small speakers over monster floorstanders... but I want the best quality for my money. Maybe I just haven't experienced the right home theatre setup to make me understand ;)
I'm thinking of buying from polkdirect or other ebay source. I am currently eyeing the RTi A5's / CSi 4.. but I am wondering if maybe 4 FXi4 speakers might be more in line with my needs? My amp is a Onkyo 606 so I need to keep it efficient as possible. (dont need massive loudness, particularly)
Anyone want to argue one way or another? Thanks...
Post edited by blakflag on
    VR3 Posts: 29,397
    edited October 2008
    Alot of people like floorstanders because nothing can replace displacement...
    However, a good bookshelf will outperform a floorstander in clarity and staging...
    I like a floorstanding for the extra bass response and the larger sound it puts out...
    Definitely personal preference
  • Early B.
    Early B. Posts: 7,900
    edited October 2008
    Not sure about that one. It sorta contradicts the reason people like floorstanders. I'll bet if you put the Taylo reference monitors up against the 7U's in your room, I doubt that the monitors will provide better clarity or staging.
    As you said, with floorstanders displacement is the draw, but that equates to a bigger stage. I think the clarity issue may come into play with the bass of floorstanders not being set up properly in the room, so it can affect clarity.
    "God grooves with tubes."
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    Larger drivers move/energize more air. The little ones just don't do it for me any more.
    Ben
  • Music Joe
    Music Joe Posts: 459
    edited October 2008
    blakflag get thy read on and check out this article. It's interesting.
    "2.5 Cheers For Stand Mounted Moniters"
  • George Grand
    George Grand Posts: 12,258
    edited October 2008
    Because if you want that BIG, real sound, you need to use real big speakers.
    treitz3 Posts: 19,952
    edited October 2008
    Hmmmm, if you don't know, you don't know.
  • George Grand
    edited October 2008
    Big speakers can sound like the real deal without breaking a sweat. There is a certain effortless character that indicates to you that as loud and accurate as it might be right then, going even further clockwise would somehow, just make them louder.
    Smaller speakers usually don't have this going for them.
  • Face
    Face Posts: 14,340
    edited October 2008
    There's no replacement for displacement.
  • Early B.
    edited October 2008
    Music Joe wrote: »
    The author doesn't know WTF he's talking about.
    With speakers, go big. Big as you possibly can.
    edited October 2008
    There are limitations though, as with most speakers.
  • ben62670
    edited October 2008
    The author states the monitor was 12x12x24. Nobody would use a semi square box. The general rule is 3x4x5. I prefer a larger speaker;)
    Ben
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    For me, it came down to floorstanders were really not that much more than bookshelves when you factor in decent stands for them. Also they were significantly more stable than speakers on stands would be. (important with kids and large dogs running around)
    That and I just like the look for floorstanders more.
    Michael
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2008
    blakflag wrote: »
    Hi all,
    Well, since most speaker manufacturers top-of-the-line speakers are floor standers that should be a clue. Plus they just look better than little wimpy speakers on stands.
  • ben62670
    edited October 2008
    BlueFox wrote: »
    And they don't take up any more floor space:)
    Ben
    F1nut Posts: 51,693
    edited October 2008
    I'm going to amend your comment to say, can outperform in those areas, but a good floorstander can and will outperform a bookshelf in all areas.
    There is no subsitute for large radiating surfaces and a man's amp.
  • danger boy
    danger boy Posts: 15,722
    edited October 2008
    how about SDA CRS+'s? they are bookshelf, no? and outperform other floorstanders in certain areas :p
    runs and hides :)
    PolkFest 2012, who's going>?
    F1nut Posts: 51,693
    edited October 2008
    Al, from first hand experience.....the CRS+ are very good bookshelf speakers, IMO. However, compared to the bigger SDA's, they don't hold a candle.
  • Polksaladanni
    Polksaladanni Posts: 208
    edited October 2008
    I'll give you my personal 2ch opinion when the RTi8's get here. I will be able to hear first hand between a dual 6.5" bookshelf RT55i vs dual 6.5" RTi8 tower.
    From what I've seen from R&R on the RT55 and RTi6 there is no difference in the woofers except the dustcaps and cone colors. Both are 4.1ohms. So the 8's got to be the same.
    I got the 8's because I have had stands for the last 20 years and the cherry finish. Before that I had several large driver tower/floor speakers. I hope the 8's are not too bass heavy/muddy.
    Personally though, I love the complete separation of the low bass freqs/res/standing waves from the the mids and highs, via a quality powered subwoofer in it's own box.
    Paul
  • pearsall001
    pearsall001 Posts: 5,242
    edited October 2008
    A floorstander is nothing more than a monitor wanna-be all stuffed into a larger cabinet (a design flaw from the start). The designers spend more time trying to overcome the problimatic issues with trying to do everything in one cabinet properly.
    A monitor will out perform a floorstander in all areas but the bass department. However the difference in bass is the downfall of the FS.
    In probably all room placements, where you have the FS is more than likely the actual worst location for "quality" bass reproduction. Now you pair the monitor up with a good sub or two (properly located, calibrated & dialed in) & watch the FS cower & crawl into the corner with it's tail between it's leg.
  • maximillian
    maximillian Posts: 2,149
    edited October 2008
    What about the LSi15's and 25's. To me they seem like LSi9's with a built-in subwoofer. The other difference is that the 9's are meant to handle all the bass. The cabinet and crossover of the FS LSi's in the upper portion do not carry the bass potion. So would 9's and a great subwoofer outperform the FS LSi's?
  • BjornB17
    BjornB17 Posts: 752
    edited October 2008
    i'm not so sure i can agree with much of what has been said...
    I think in many cases a floorstander will outperform a bookshelf. of course there are cases where this isnt true but it always has been true in my experience.
    example: Comparing my RTi10s to the RTi4 and RTi6's that i have. The bookshelves, while they sound alright, have a muddy upper-bass and and non-existant lower bass. with the woofer trying to provide such a wide range of frequency response, it seems that the mids are negatively impacted. the RTi10s separate things much better, the mids and bass dont get jumbled together. I've tried both with and without a sub, and in either case i think the floorstander sounds much better.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2008
    x2....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Early B.
    edited October 2008
    Ha ha. You've been living with yor AAD 2001's for too long. Those monitors can definitely spar with the big boys, but they are a rare exception.
    I previously had a stereo sub setup and loved it. It was the best bass I heard, until recently. I changed the configuration of my setup (same speakers, but now along the short wall), changed a couple of components, and the bass is astounding. I didn't think it was possible. I haven't felt the need to add the dual subs again. The secret is in the setup. The vast majority of people with floorstanders don't have a clue about proper placement, but instead will damn all floorstanders to hell. (OK, so maybe that's a slight exaggeration.)
  • John30_30
    John30_30 Posts: 1,024
    edited October 2008
    ben62670 wrote: »
    Like that Greek guy. Nice, thanks.
  • blakflag
    blakflag Posts: 3
    edited October 2008
    wow thanks for all the input. Maybe I should just take the leap for some floorstanders. I will check out folks other recommendations but I have a feeling I won't have the coin for some of them. :)
  • pearsall001
    edited October 2008
    Early B. wrote: »
    I was waiting for your response! ;)
    With floorstanders it's all about placement...most of the time with lack luster bass performance (due to sharing the same cabinet with the other drivers, XO, etc.). I'm glad to hear that you found the ideal spot for those bad boys. Now to really make them sing...put the subs back in!!! Now we're talking!!
    And you're right...those AAD 2001 monitors are a rare breed! Still loving 'em.
  • zingo
    zingo Posts: 11,258
    edited October 2008
    The floorstand argument is definitely true when it comes to horns. There is a rare pair of decent horns in bookshelf form (Klipsch RB-75), but mostly floorstands because of the required size.
  • Early B.
    edited October 2008
    Really glad to see you're still lovin' on those AAD's.
    Yeah, eventually, I'll add the subs back in. Next time, though, I'll want to move beyond the 10" DIYers. Maybe a couple of 12" or 15" Onix subs. or the dual Emo subs with room correction and separate amplification. However, space is a major issue.
  • pearsall001
    edited October 2008
    Early B. wrote: »
    Sounds like you have a nice plan for the cold months ahead. I hear ya on the space issue though. Happy listening.
  • Music Joe
    edited October 2008
    Early B. wrote: »
    What did you see wrong with the sidebar article? Just asking.
