which amp?
bmsavoie
After a year and a half of collecting I finally have all the speakers I want, for now.The next step is amps, because it is just not loud enough, I am looking for suggestions and or advice on amps. Thanks in advance.
Post edited by bmsavoie on
Welcome to the forum bm. There's no easy answer to your question. We need to know more about your system. Which pre-amp will you be using? Which speakers do you own? How much are you willing to spend?
As for the amps, Rotel, NAD, B&K, Adcom all make good stuff.
Maurice -
Thanks organ, have not made any desicions about anything yet just trying to figure the whole amp, pre-amp thing out. Price hasn't been decided yet either, depends what i figure i need, i guess? Anyhow here is my system, thanks Receiver- hk avr520
DVD- rca
TV- sony wega kv-36fv300
Mains- rt2000i
Center- cs400i
Surrounds- fx500
Sub- psw450
Cables- monster -
I don't know much about HK receivers but I bet the one you own has pre-outs. You can look at some 5ch amps. If you're into stereo a lot more than HT you can spend the same amount of money and use a 2ch amp only for the mains(shoud sound better than same priced 5ch).
Maurice -
I'm thinking ditch the HK and get into a better receiver.......a thoughtDan
Thanks for the input, I think now I will start looking into recievers to see what's out there.
I say ADCOM!!!!!!!!!!!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
welcome bmsavoie, give us some more imfo, how much you want to spend, what speakers you have , whats your amp now.. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
Joe, do you even read these threads? BM gave his system specs and wants/desires 3 or 4 posts up.Originally posted by bmsavioe
Receiver- hk avr520
DVD- rca
Mains- rt2000i
Center- cs400i
Surrounds- fx500
Sub- psw450
Cables- monsterDamn....8 lines...I've gotta put my sig on a diet now.... -
i say get a good power amp and use yor hk as a pre. that is my upgrade path. adcom is nice and so b&k i havent herd much else. i got a 7 channel adcom for 1300 7 channels 125 a channel. the shop i got my amp at had a b&k 200 a channel on sale for 2k. i am new to the power amps thing so i am lerning too. stick around and you can lern too.
Best bang for the buck---Rotel
Rick -
Since some of you are adding your best bang for the buck amp, I thought I'd add mine......NAD BABY!!!!!
Don't be too concerned about the pre at the moment. Try using your H/K as a pre first and see if you're satisfied with it's performance as a pre-amp both for HT and stereo. If you're not happy with it's HT performance, look for a HT pre/pro(can get pricey). If you're not satisfied with it's stereo performance, add a 2ch pre to the mix.
Maurice -
b,
I agree with the others about using your HK's front end a while. You seem to have been patient so far, so why jump straight to a new AVR now? IMO put your bucks in the power at this point.
But regardless, are we talking strictly new electronics or are you open to used?More later,
Tour...
Vox Copuli
thanks everyone, used equipment would be fine if in good condition and a decent deal. Still have to do the research on amps havn't had the time lately, hoping to get to it soon, but just reading in the forum has taught me quite a bit so far. As for time , with 3 kids between 8 and 1 1/2 , waiting is the only way I get my toys. thank for all the advice everyone.
