my setup
Are you effing kidding? The hole was off? Who did you buy those from? You gotta get a new plate! Did you get it new from Underwood Hifi?
the hole for the middle 2 bolt was slightly off - no biggie, its fixed. i got them from walter, new.
did you follow the instructions, the distance a, b and c and d? i cant seem to get the ideal placement...hopefully audyssey will take care of it...
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
moving stuff around.......
my 7.(1x4) HT setup
Buttkicker
They are a pain in the **** to place, but once you get it right, they sound amazing. My toe-in intersects about an inch in front of my nose . . .
I'm hoping the lamp on ceiling doesn't blast.
i have not fired them up yet...waiting for franks xlr cables to show up
what i manage to position so far:
A=4'
B=7', too short as thats almost in the middle of my square room...bass is ZERO there...
C=20'
D=8'
these speakers very easy to assemble/setup, light enough to be move around w/o help, is triple spiked - makes toe-in a breeze.
my 7.(1x4) HT setup
Buttkicker
8 feet is the optimal distance between the speakers. Also, I noticed they have a significantly larger soundstage and cleaner separation when I sit about 11 feet away from the speakers. Recently, I was sitting 8 feet to have a perfect triangle, but 11 feet seems to be the sweet spot in my room.
:eek:
they might rattle loose from their sockets tho...:pmy 7.(1x4) HT setup
Buttkicker
SolidSqual wrote: »8 feet is the optimal distance between the speakers. Also, I noticed they have a significantly larger soundstage and cleaner separation when I sit about 11 feet away from the speakers. Recently, I was sitting 8 feet to have a perfect triangle, but 11 feet seems to be the sweet spot in my room.
D=8"
B=11'
whats your A & C?
which of the RPF preset file # did you use?my 7.(1x4) HT setup
Buttkicker
I use the preset with the most bass. I think that's seven or something. Don't remember right now, but I like it that way. I'm four feet from my back wall and about 3 feet from the side walls.
I miss The conquest alreadyAudio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
I was wondering were you put the sub.
engtazengtaz
SolidSqual wrote: »I use the preset with the most bass. I think that's seven or something. Don't remember right now, but I like it that way. I'm four feet from my back wall and about 3 feet from the side walls.
i'll just try all the settings and see whats the better sounding onemy 7.(1x4) HT setup
Buttkicker
That's what I did. -
I want to hear your review SlowCar! I'm DYING to hear those speakers!
I'm looking to build something similar using a Vifa XT tweeter.
I hope it works out for you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Hi Guys,
The mounting bolts that protrude from the bottom of the CS2 speaker are actually the ends of U-bolts. It appears that some of these have a slightly different center-to-center spacing at the ends from the bending process. This can cause a misalignment when mating the base to the speaker.
We have addressed this potential issue by machining the inside holes of the base in a racetrack shape which accounts for any variations in the U-bolt shape.
Thanks,
Clayton Shaw
Emerald Physics -
L/R = Emerald Physics CS2
C = JTR Triple 12LF...it is big!
my 7.(1x4) HT setup
Buttkicker
You are insane!!!
Whats next? Nice setup.
lol
i hope the shelf holds up.....the speaker is ~130lbsmy 7.(1x4) HT setup
Buttkicker
Cat looks like he likes em lol.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
So after all the speakers you have gone through, which is your favorite? Which had the best soundstage, best imaging, best overall sound, etc? Which do you think was the worst? Do you think you will ever be settled? Are you going to try Kplisch or B&W?
Thanks for your hard work in trying all these different configurations out. It's been fun reading this thread. -
Go B&W next Slow, 802Ds would look nice in that room. Have to admit you've had some awesome toys in the past few months. Love that center, freaking huge.Shoot the jumper.....................BALLIN.............!!!!!
from the brief listening - this might be the last time i change LCRmy 7.(1x4) HT setup
Buttkicker
maximillian wrote: »So after all the speakers you have gone through, which is your favorite? Which had the best soundstage, best imaging, best overall sound, etc? Which do you think was the worst? Do you think you will ever be settled? Are you going to try Kplisch or B&W?
this is by far the best combination. the soundstage spans the whole front wall, also due to so many big drivers, its able to move so much air - its a real moving experience, the tactile sensation so real. I have watched the transformer movie uncountable times on my previous speaker setup and also at demo room at the local high end ht dealer - none comes close to what this current setup can do.my 7.(1x4) HT setup
Buttkicker
I was going to mention that you need some larger speakers if you want any air movement at all. Especially if you are trying to rely on bass just from that little twinky of a sub you have.....
:rolleyes::p Mains.............Polk LSi15 (Cherry)
i dont think i will go away from proaudio stuff, i have been really impressed by them being able to play loud and clean/clear.
if or when i decide to change lcr again, it will be these:
http://www.danleysoundlabs.com/synergy_horn.asp?model=SH%2050
and this sub
http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%2050my 7.(1x4) HT setup
Buttkicker
:rolleyes::p
theres no replacement for displacement
my 7.(1x4) HT setup
Buttkicker
and this sub
That danley sound lab speakers look like concert type speakers.
