my setup
15791011
    edited September 2008
    Are you effing kidding? The hole was off? Who did you buy those from? You gotta get a new plate! Did you get it new from Underwood Hifi?
    the hole for the middle 2 bolt was slightly off - no biggie, its fixed. i got them from walter, new.
    did you follow the instructions, the distance a, b and c and d? i cant seem to get the ideal placement...hopefully audyssey will take care of it...:confused:
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
    moving stuff around.......
    my 7.(1x4) HT setup
    Buttkicker
    They are a pain in the **** to place, but once you get it right, they sound amazing. My toe-in intersects about an inch in front of my nose . . .
    I'm hoping the lamp on ceiling doesn't blast.
    i have not fired them up yet...waiting for franks xlr cables to show up
    what i manage to position so far:
    A=4'
    B=7', too short as thats almost in the middle of my square room...bass is ZERO there...
    C=20'
    D=8'
    these speakers very easy to assemble/setup, light enough to be move around w/o help, is triple spiked - makes toe-in a breeze. :)
    my 7.(1x4) HT setup
    Buttkicker
    8 feet is the optimal distance between the speakers. Also, I noticed they have a significantly larger soundstage and cleaner separation when I sit about 11 feet away from the speakers. Recently, I was sitting 8 feet to have a perfect triangle, but 11 feet seems to be the sweet spot in my room.
    MKZ wrote: »
    :eek:
    they might rattle loose from their sockets tho...:p
    my 7.(1x4) HT setup
    Buttkicker
    SolidSqual wrote: »
    D=8"
    B=11'
    whats your A & C?
    which of the RPF preset file # did you use?
    my 7.(1x4) HT setup
    Buttkicker
    I use the preset with the most bass. I think that's seven or something. Don't remember right now, but I like it that way. I'm four feet from my back wall and about 3 feet from the side walls.
    I miss The conquest already
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Panasonic:TH-42PX60U 42"Plasma
    Power Conditioner:
    Monster Power
    : HTS 3600 MKII Home Theater
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
    I was wondering were you put the sub.
    engtaz
    engtaz
    SolidSqual wrote: »
    i'll just try all the settings and see whats the better sounding one
    my 7.(1x4) HT setup
    Buttkicker
    SlowcarIX wrote: »
    That's what I did.
    I want to hear your review SlowCar! I'm DYING to hear those speakers!
    I'm looking to build something similar using a Vifa XT tweeter.
    I hope it works out for you.
    Hi Guys,
    The mounting bolts that protrude from the bottom of the CS2 speaker are actually the ends of U-bolts. It appears that some of these have a slightly different center-to-center spacing at the ends from the bending process. This can cause a misalignment when mating the base to the speaker.
    We have addressed this potential issue by machining the inside holes of the base in a racetrack shape which accounts for any variations in the U-bolt shape.
    Thanks,
    Clayton Shaw
    Emerald Physics
    edited October 2008
    L/R = Emerald Physics CS2
    C = JTR Triple 12LF...it is big! :D
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    You are insane!!! :D
    edited October 2008
    Whats next? Nice setup.
    edited October 2008
    lol
    i hope the shelf holds up.....the speaker is ~130lbs
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    Cat looks like he likes em lol.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
    edited October 2008
    So after all the speakers you have gone through, which is your favorite? Which had the best soundstage, best imaging, best overall sound, etc? Which do you think was the worst? Do you think you will ever be settled? Are you going to try Kplisch or B&W?
    Thanks for your hard work in trying all these different configurations out. It's been fun reading this thread.
    edited October 2008
    Go B&W next Slow, 802Ds would look nice in that room. Have to admit you've had some awesome toys in the past few months. Love that center, freaking huge.
    edited October 2008
    leroyjr1 wrote: »
    from the brief listening - this might be the last time i change LCR
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    this is by far the best combination. the soundstage spans the whole front wall, also due to so many big drivers, its able to move so much air - its a real moving experience, the tactile sensation so real. I have watched the transformer movie uncountable times on my previous speaker setup and also at demo room at the local high end ht dealer - none comes close to what this current setup can do.
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    SlowcarIX wrote: »
    I was going to mention that you need some larger speakers if you want any air movement at all. Especially if you are trying to rely on bass just from that little twinky of a sub you have..... :p:rolleyes::p
    edited October 2008
    Sherardp wrote: »
    i dont think i will go away from proaudio stuff, i have been really impressed by them being able to play loud and clean/clear.
    if or when i decide to change lcr again, it will be these:
    http://www.danleysoundlabs.com/synergy_horn.asp?model=SH%2050
    and this sub
    http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%2050
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    McLoki wrote: »
    :D theres no replacement for displacement :D
    my 7.(1x4) HT setup
    Buttkicker
    edited October 2008
    SlowcarIX wrote: »
    and this sub
    That danley sound lab speakers look like concert type speakers.
Welcome!
Welcome!
