Another Possible Ridiculous Question
RTi8's are practically being given away right now....so I was thinking if it would be ridiculous to stack them? I would leave the feet off the second pair and brace it from the back....also reinforcing the bottom feet for more support. Amp would be running around a 4ohm load with 4 8ohm speakers to 2-channels.
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Post edited by curved on
You should ban yourself immediately."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
This forum does not take well to radical ideas of pseudo-audio-philes who call themselves 'stackers'
Do a search on stacking LSi9s and similar and you will soon see what kind of reaction you get if you pursue this slippery idea ... LOL.
Z -
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
I was thinking about doing it because I like to listen to my music LOUD. I'm fairly happy with the sound of my speaks.
The other posts were about stacking bookshelves on top of towers. Now that's ridiculous!
Maybe I should just get SDA's.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Stacking as you described would be okay as long as you gutted the bottom RTi8 speaker, filled it with sand, and then placed the other RTi8 on top and elevated your listening chair about 3 - 4 feet from the floor.:D
Always a funny guy
Pre - Nak CA-5
BR - LG BD390
Stack away. It's your stuff, money, and ears. If you like it then yes, if not, then no.Make it Funky!
must be going for the "wall of sound" effect--Phil SpectorJC approves....he told me so. (F-1 nut) -
The reason I was actually thinking about this idea:
I may be buying my in-laws house - the wall where the TV is going is 25-30 feet high (ranch). The room is about 800 sq ft.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
The other posts were about stacking bookshelves on top of towers. Now that's ridiculous! .
Damn, thats exactly what I was considering doing (stacking LSiFX on top of LSi15s for the rear surrounds).Do you hear that buzzing noise?
I agreeDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Give it a shot. I doubt it will be that great for critical listening, but then again - that may not be what you want. If it sucks, you can always use them as rear surrounds....Mains.............Polk LSi15 (Cherry)
How would you stack them - Tweeters to Tweeters (top RTi8 updside down) or both right side up?
You might as well save the money you would spend on 2 pairs of Rti8s and get something meant to give BIGGER sound without stacking ...
But if you are still interested read SlowCar's discussion with members on the subject ...
http://www.polkaudio.com/forums/showthread.php?t=69504
http://www.polkaudio.com/forums/showthread.php?t=70249&highlight=stacking
Zsolt
