My Center Channel tweak still under construction...
2
  • hoosier21
    hoosier21 Posts: 4,415
    edited May 2003
    That is the freaking coolest thing I have seen, I want one. What ga doing with the other RTA15tl?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    VR3 Posts: 29,397
    edited May 2003
    You know, that is friggin awesome. Looks like a CS400i on drugs. LOL! Has the same type of grill, same look, just alot bigger! SHEAT! ROCK ON! Good job! I want one too!
    F1nut Posts: 51,693
    edited May 2003
    Hey cuz,
    SWEET!!!
  • gidrah
    gidrah Posts: 3,049
    edited May 2003
    Looking real good man!
    If you add more bracing for the weight of the TV, I'd try to run them between the mid/woofs and try to go back 4" or so. This will support the TV and block any back waves of one driver from interfering with the other. You could also run them after the outermost mid/woofs to make sure the PR reacts to only the full wave of the enclosure and not the closest part of the fastest wave of the nearest driver.
    Make it Funky! :)
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2003
    Damn!
    Har, you sir are a MADMAN. That thing looks GREAT.
    Hoosier, I think Har and F1 'split' a pair of 15's for exactly this project.....
    Cheers,
    Russ
  • joe logston
    joe logston Posts: 882
    edited May 2003
    har_navalta, its a real nice center speaker you built,
    you should try to get a job at polk audio.
    thanks for sharing the pictures with us.
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • har_navalta
    har_navalta Posts: 957
    edited May 2003
    Thanks everyone for the appreciation... I will keep you updated until this thing finished with pictures.
    gidrah, thanks for the suggestion too. Yes I will run about 4 pieces of vertical supports between the woofs, 2 in the front and also 2 at the back. Originally suggested by Jesse and other members. I will do it by the weekends.
    This thing is pretty heavy because of the Solid ASH wood top and
    bottoms.
    hoosier, yeah Russ was right. Jesse and I split a pair of 15's for this purpose (because of the SL3000 tweets).
    Micah, do I qualify for a job at Polk?
    This is a one of a kind Center Channel. :)
    Har
  • har_navalta
    edited May 2003
    hoosier,
    Are you going to make one also? Did you get the 15TL's instead
    of Jesse?
    What type of cabinet are you going to make? Probably the same like mine;)
    Har
  • hoosier21
    edited May 2003
    Looks like the RTA15tl's will be mine.
    I will be building something VERY close you yours, have not really put pencil to paper yet.
    A thought I have is to make the front face taller to allow the PR to be in the front.
    Also wondering about using all the drivers from both speakers, but that is really just a wild thought so far.
    I will have to first pick the TV to go on top, then plan from there.
  • har_navalta
    edited May 2003
    That's what I am thinking it before to be in the front but decided
    to placed them on the sides. Love to have them on the sides
    though.
    Har
  • hoosier21
    edited May 2003
    did you say you WERE going to put them in the front and you want them in the front?
    What made you put them on the sides?
  • har_navalta
    edited May 2003
    I don't want them in the front because it looks stupid that is
    why I put it in the sides.
  • warlocks1
    warlocks1 Posts: 1,260
    edited May 2003
    With all these center channel being made out of RTA15tl's will someone PLEASE sell me one of the RTA15 grill logos. If someone has one email me at Warlocks1@aol.com. Thanks, Jeff
    BTW, the center looks awesome.
  • burdette
    burdette Posts: 1,194
    edited May 2003
    I guess I have the baby-brother project. I am planning on building a center channel from the components from an RTA8T (an SL2000 and two 6510s), as soon as I can scrounge the dough for the 6510s Hbomb is holding for me. This would be to match the Monitor series I have all the way around (except for center). I've got the tweeters and crossovers. My only question is whether I build a center using the components from one speaker, or two. I don't really think I need a center with two SL2000s and four 6510s... but if I use only half of them, I don't have anything to do with the other half, except hold them for parts.
    Anyway, hope to get going on this soon. I may do a hurry-up project and build a center into the VCR space on our TV cart. I could use half the drivers and at least have a fun experiement and a better center while I build the separate box.
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2003
    They remain your's for the taking.
    HBomb
    ***WAREMTAE***
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2003
    Har:
    Looking amazing! What weight PRs are you using for the sides and how did you arrive at that design decision?
    Doc
    SVS
  • har_navalta
    edited May 2003
    Doc,
    I will answer your questions when I get home from work:) too busy.
    BTW, good question.
    Har
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2003
    Awesome, professional job Har. What were the materials costs for this project?
  • madmax
    madmax Posts: 12,434
    edited May 2003
    Very professional job Har.
    madmax
    Vinyl, the final frontier...
  • hotwheelman
    hotwheelman Posts: 1,300
    edited May 2003
    You know....I had tried to imagine what it was going to look like and I can honestly say I had no idea that it was going to look like
    and that it would look that damn good, I can't wait to see the final results. I would like to do one but it will have to more low profile than the one you have built in order to keep the big screen from being next to the ceiling. Job well done har!:cool:
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • har_navalta
    edited May 2003
    I did a research on which Polk Center Channel will match my SDA's TL version and nothing comes close, even their top of the line which is the CS1000p. I came to a decision; I will make the RTA 15TL to an excellent Center Channel especially
    with the SL3000 tweeter because I know how. The only Alternative to acquire one will be from my favorite shopping store and that's eBay. At that time there is one available. I need only one, so I spoke to f1nut(Jesse) if he is interested to get the other Channel. He let me do the bidding. We finally got it to $326.00. At that time I was already thinking of what type of Cabinet Enclosure has to be done.
    The purpose of this Center Channel is to make a Table Top for a
    Plasma 50" tv and matches my SDA's (with SL3000's).
    The Design Criteria will be:
    1. For a table top, it should only be the same height as a coffee
    table.
    2. The Plasma TV Screen should be adjusted to eye level when sitting on a couch.
    3. The Center Channel character would work more on furniture type not just speaker alone to adapt any type of Family Room,
    Living Room or a Home Theater.
    4. To match the coffee table the maximum height will have to be 19".
    It may have to be a little lower but it should not be higher than 19".
    I decided to place the Passive Radiators in the sides similar to
    PSW 1200, PSW 650 and the upcoming PSW 808.
    I think this way it will add more impact between the 2 Front
    Main Speakers.
    The RTA 15TL has more Bass than any Center Channel out there:)
    Har
  • dthomps
    dthomps Posts: 352
    edited May 2003
    Hey Har-
    Sounds like things are coming along very nicely. You have how many projects going right now, and still manage to pull off this kind of work? I am very impressed, again. If I even attempted to take on as many things as you have going I would totally screw everything up, I wish I could build things like that.
    Awesome job bro, keep it up.
    Good luck
    Mike
  • hoosier21
    edited May 2003
    Har - do you have to worry with shielding when you have a Plasma?
    Anybody - I am leaning towards the Sony 50" or 60" LCD tv, is shielding an issue with these tv's?
  • faster100
    faster100 Posts: 6,124
    edited May 2003
    wow, what do those things cost? and what is the contrast ratio compared to a standard tube tv? or RPTv, i heard and read that lcd doesn't have the brightness/contrast that tube TV's have..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • hoosier21
    edited May 2003
    CC sells the 60" for 4999.99, and the 50" for 3999.99.
    I have a Sony connection, so I can get these for a better deal than that, but it is still TOO DAMN much money for a TV.
    The LCD does have problems with black, I need a better demo to see if it will bother me, they have only played Toy Story or some such when I have seen it, I want to see something real played on it.
    The deal is not closed, I am still looking at RPTV's.
  • faster100
    edited May 2003
    Plus, whats the shelf life of a Lcd?? i heard that don't last long.. Well considering say a tube, and is there a difference between plasma and lcd??
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • weavercr
    weavercr Posts: 289
    edited May 2003
    Outstanding job Har, It the best Home built speaker I have seen in a long time.
  • har_navalta
    edited May 2003
    I buy them by little pieces not the standard 4'x8'
    The materials of Cabinet Enclosure:
    2 pieces of Lawanit 1/4"x2'x4' each $5.99
    4 pieces of speaker board 1/2"x2'x4' each $9.99
    Spend 2 bottle of Carpenters Glue each $6.99 350ml
    3 pieces of 3/4"x8"x6' Ash Wood each $21.00
    Glued and clamped together to make
    it a solid 1-1/2"x14"x37"
    Grille Frames:
    1 piece 1/2"x2'x4' board(similar to lawanit) $9.99
    Total expenses = $139.00
    I painted the Grille frames a while ago with Flat Black and
    it will be ready to glue the Grille cloth on them.
    F1nut Posts: 51,693
    edited May 2003
    Hey cuz,
    WTH is Lawanit???
  • har_navalta
    edited May 2003
    I don't know what it's called I will go tomorrow to the lumber
    store and verify that board name.
