Cable burn in question
NotaSuv
NotaSuv Posts: 3,871
I know you can use a Cd player set on repeat to burn in interconnects..Can one use a Direct TV HD receiver the same way? If the receiver is on and connected to a pre amp and the pre amp is set to TV, would this have the same effect as using a CD player ,as it also could be left on for days........
Post edited by NotaSuv on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited September 2008
    It depends. If you think it will have the same effect it will, if not, it won't work as well.
  • leroyjr1
    leroyjr1 Posts: 8,785
    WilliamM2 wrote: »
    :confused:
  • leroyjr1
    My girlfriend and daughter watches alot of movies(lifetime & spongebob), reality shows and listen to directvs xm radio so I put my IC cables between the tv and sat. box and I leave then for a week.( about 50 hours)
  • Face
    Face Posts: 14,340
    Yes, that'll work fine.
  • NotaSuv
    Thanks all.......figured it would do the same.....and since the wife always has her set on......
  • NotaSuv
    WilliamM2 wrote: »
    WOW really lost me on that reply...............
  • ben62670
    ben62670 Posts: 15,969
    NotaSuv wrote: »
    William believes all cables sound the same, and there is no such thing as burnin.
    Ben
  • NotaSuv
    ben62670 wrote: »
    I was that naive once too :rolleyes:
  • ben62670
    NotaSuv wrote: »
    I believe some people just can't hear it. 9 times out of 10 people describe the same exact thing when switching to my cables:)
    Ben
  • Willow
    Willow Posts: 11,231
    ben62670 wrote: »
    One day I will try yours! just no need to replace anything right now.
  • Logic 7
    Logic 7 Posts: 127
    edited October 2008
    I believe in suing good cables but have never heard of burning them in. Speakers maybe but cables?
  • Strong Bad
    Strong Bad Posts: 4,278
    edited October 2008
    Willow wrote: »
    This just doesn't sound right man! You wanting to try Ben's "Cable." Something we should know? :D
    No excuses!
  • zingo
    zingo Posts: 11,258
    edited October 2008
    Strong Bad wrote: »
    I'm next in line...:eek:
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2008
    NotaSuv wrote: »
    But then you have to disturb the cables when you disconnect them and put them where you want them. Then your copper molecules will be in a different position than what they were during burn in.
  • Systems
    Systems Posts: 14,873
    edited October 2008
    PolkThug wrote: »
    yeah thats what I was thinking too.:D
    Testing
    Testing
    Testing
  • phuz
    phuz Posts: 2,372
    edited October 2008
    WilliamM2 wrote: »
    Schrödinger's Cables. :p:p:p
  • NotaSuv
    edited October 2008
    PolkThug wrote: »
    I had to buy a specially charged shammie made from spun zenonite crystals......this insures that the copper molecules assume the correct molecular structure needed for the bestest sound.....and they let me pay the shammie off over 60 months..... score :D
  • kolyan2k
    kolyan2k Posts: 259
    edited October 2008
    ben62670 wrote: »
    thats not a believe....its a fact.
  • Face
    Face Posts: 14,340
    edited October 2008
    Suuuuure they do.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited October 2008
    While I believe a cable can add or subtract something from the overall sound of a system, I have never believed in cable "burn-in". I think it is more of my ears burning in to the new sound of the new cable.
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • zingo
    zingo Posts: 11,258
    edited October 2008
    I tried burning in my ears once, but I think the voltage I used was too high. :eek:
